Rear lined/thick/panel material?
Discussion in 'Cosmetic & Restoration' started by 63rarewingedgod, Mar 19, 2008.
  1. Stormin' Norman
    This is the stuff you want to really get that rust fungus out!
    http://www.porcan.com/usa/metalprepdegrease.asp
    Then prime it with a Rustoleum primer and paint 2 or 3 coats. POR-15 is good too. Its a high wear area, and when you glue down the new flooring it will just bubble and rust again otherwise. That's the rubber flooring right?
