Ford Ltd Crown Victoria diagnostics
Discussion in 'General Automotive Tech' started by crownvictoria, Dec 5, 2015.
  1. Silvertwinkiehobo
    As an example, I had that '83 Colony Park with EEC III/CFI, which was not OBD I. the next year, '84, which had EEC IV/CFI, was OBD I because the EPA tightened emissions standards for the '84 MY.
  2. KevinVarnes
    Its your money, but most OBD I are limited in what you can do anyways. Not all offer any type of data streaming. Frankly I've never needed it for OBD I anyway. I just don't think it is worth it to get a fancy scanner to use on older cars when you can't do much with the older cars anyway. I suppose if you are working on a bunch of 15+ y/o OBD II cars then it might be great. If I were in the market for a scanner I wouldn't even bother with this one since most of the cars I work on nowadays are max 8-10 years old. The scanner I have supports all OBD II cars.
  3. crownvictoria
    crownvictoria Member
    southern Germany
    thanks to all for your valuable input!
    In most points, I totally agree with you.
    as mentioned earlier, I wouldn´t think about buying a scanner for my Ford only. My Trans Sport definitely has OBDI and my hope is to get deep access to the ecm and other systems. From what I´ve heard, this is not possible with the low price scanner tools. Resetting or erasing failure codes, ok, but not digging into the system and getting detailed information or sensor readings. According to my information cheap scanners are not able to support you adequately in trobleshooting, only give you an idea what could be wrong.
    OBDII currently is out of my scope as I only own one OBDII car.
    Maybe it´s also a different situation between the U.S. and Germany. Here, it is very hard to find a shop that is capable of working on the older U.S. cars. Oh yes, there are a lot of dealers, and most of them provide a certain level of service, but not a shop you can trust. So, if you want to keep your old U.S. car running, and I WANT that, you are on your own. :(
    I know for my trans sport there is the possibility to get access with an interface and a DOS computer. Unfortunately I neither have a DOS laptop nor the interface which is no longer available as they had been handmade by a member of the trans sport forum. They choose this alternative as the professional scanners are either too expensive or not available or both.
    Anyway, if my Ford grants access to its system with this scanner and a specific cable (or OBDI), I could use it, no matter how much I can do.
  4. Silvertwinkiehobo
    When will you be getting the scan tool? I'd like to see a pic or two of it and the accessory connectors. An MT2500 will have cartridges to plug into the body, a single cable with standard parallel connectors, then connector 'heads' you attach on the cable to connect to the car's diagnostic connector. It should also have a separate power cable that plugs between the connector head and the cigar lighter to power the scan tool. And you should have a couple 9 volt batteries to power the scan tool before you hook it up. If you can take those pics, I can tell you if you're missing anything.
  5. OldFox
    OK, I have both an OTC Monitor 2000 and a Matco 4000E which is made by OTC for Matco and is the later version. I have scanned the older manual and made it into a PDF file which should be attached. It should tell you what is available, diagnostic wise, for your car and also shows the adapter. Sorry it's sideways but it wouldn't fit in my scanner the other way. If you print it out and assemble it in landscape mode, it should read OK.
  6. Silvertwinkiehobo
    Anyone have any of the literature for the MT2500? Since I had to quit working, I don't have any access to those books anymore.
  7. crownvictoria
    southern Germany
    Thanks for the help! The pdf is VERY ok!
    I will check my car for this Ford self-test connector. Seems that this could be the correct entrance to the car´s system.
    I am not sure when exactly I buy it. If yes, then within short. In fact, due to the conversation here I am a bit confused. As far as I remember the case contained the tool itself and certain cartridges for U.S. cars covering up the big three up to year 2000 and some European makes. Right now, thinking about it, I am not sure if there were cables in the case or not. I will have to check with my sales person.
  8. OldFox
    Just to be clear. Neither of my units came with the 2 wire Ford adapter they show, nor did I ever require it between 1984 and 2000. It may be that a vehicle that required it never came into my shop with problems. It may be that you will have to purchase it separately. One of my mechanics had the Snap On unit, but I don't recall what adapters he had with his.
  9. crownvictoria
    southern Germany
    I understand.
    First of all I have to understand which one is the correct connector. Seems that your pdf gives me the perfect hint. Thanks for that!
    Hopefully, I will never have this kind of problems too, but just to be prepared....when the car is down and you have to go out to search for the correct connector and have to buy cables and cartridges first...(n)
  10. Silvertwinkiehobo
    Well, any of the Ford EEC IV systems, regardless of engine, will require both connectors I showed in that pic I posted; the small single-wire one is the Self-Test Input (STI) trigger connector. It is what starts the computer's self-test program. Try this diagram, if you go to do the Key On Engine Off (KOEO) test:
  11. Silvertwinkiehobo
    A 2-digit code list I found:
    11 System checks OK -
    12 Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too low)
    13 (O) ISC did not respond properly (extends to touch throttle then retracts for KOEO)
    (R) Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too high)
    (M) ISC sticking, open ITS circuit or TP sticking
    14 Ignition pickup was erratic
    E4OD Transmission diesel RPM sensor
    15 (O) No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure)
    (M) KAM (pin 1) was interrupted (was battery disconnected ?)
    16 1.9L & 2.5L - Throttle stop set too high
    2.3L - RPM's too low
    (O) Electronic ignition - IDM circuit fault
    17 1.9L & 2.5L - Throttle stop set too low
    18 (R) Check base timing & advance function
    (M) Ignition TACH signal erratic
    19 (O) No Vehicle Power (pins 37 + 57) or bad PCM
    (R) Erratic idle during test (reset throttle & retest)
    Electronic ignition Cylinder ID sensor/circuit problem
    21 Engine Coolant Temperature (ECT) sensor out of range
    22 MAP (vacuum) or BARO signal out of range
    23 Throttle sensor out of range or throttle set too high
    24 Intake Air Temperature (IAT) or Vane Air Temperature (VAT) sensor out of range
    25 Knock sensor not tested (ignore if not pinging)
    26 Mass Air Flow (MAF) or Vane Air Flow (VAF) out of range
    Transmission Oil Temperature (TOT) sensor out of range
    27 Vehicle Speed Sensor problem
    28 Vane Air Temperature (VAT) sensor out of range
    2.3L w/Electronic Ignition - Cyl ID, IDM low or right coil pack failure
    29 Vehicle Speed Sensor problem
    EGR CODES DEPEND ON WHAT SYSTEM TYPE THE VEHICLE IS EQUIPPED WITH:
    EVP
    is for vehicles equipped with EGR solenoid(s), with or without an EVP sensor
    EVR is for vehicles equipped with an EGR Vacuum Regulator (EVR) and an EGR Valve Position (EVP) sensor
    PFE is for vehicles with Pressure Feedback EGR (PFE) sensor and and an EGR Vacuum Regulator (EVR)
    If you don't know what type of system you have, go to the EVP heading, which is the first one.
    There are pictures under the different headings to help you identify the system.
    31 EVP - (O, R, M) EVP signal is/was out of range
    EVR - (O, R, M) EVP signal is/was low
    PFE - (O, R, M) PFE signal is/was low
    32 EVP - (R) EGR not responding properly during test
    PFE - (R, M) PFE shows low pressure, EGR not seating or memory, not seating intermittently
    33 ALL - (O, M) EGR did not open/ respond during test or if memory code, did not open intermittently
    34 EVP - (R) EGR did not respond properly during test EVR - (O, R, M) EVP sensor is/was high PFE - (O, R, M) PFE sensor is/was out of range
    35 EVP - (R) Engine RPM's too low to test EGR system
    EVR - (O, R, M) EVP sensor signal is/was high
    PFE - (O, R, M) PFE sensor signal is/was high
    38 Idle Tracking Switch signal was intermittent
    39 Transmission Torque Converter clutch not engaging
    40 SERIES FUEL/AIR INJECTION CODES ON VEHICLES WITH DUAL OXYGEN SENSORS REFER TO THE RIGHT OR REAR SENSOR. EXCEPT: 1984-1988 3.8L ENGINES: LEFT SENSOR
    41
    (R) System lean
    (M) System was lean for 15 seconds or more (no HO2S switching)
    42 (R) System rich
    (M) System was rich for 15 seconds or more (no HO2S switching)
    43 (R) HO2S sensor not reading (run at 2000 rpm's for 2 minutes and retest - check for HO2S switching)
    (M) Was lean at WOT for 3 seconds or more
    44 AIR system inoperative
    45 AIR not Diverting (AIRD)
    Electronic Ignition - coil primary circuit failure
    46 AIR Bypass (AIRB) not working
    Electronic Ignition - primary circuit failure coil 2
    47 Low flow unmetered air (check for small vacuum leaks, injector o'rings, gaskets etc.)
    E4OD transmission 4x4 switch/circuit problem
    48 High flow unmetered air (check for large vacuum leak, inlet hoses etc.)
    49 Electronic Ignition - spout signal circuit problem
    Transmission 1/2 shift problem
    51 Engine Coolant Temperature (ECT) sensor signal is/was too high
    52 Power Steering Pressure Switch/circuit open
    (R) Did you turn wheel during test ?
    53 Throttle Position sensor too high
    54 Intake Air Temperature (IAT) or Vane Air Temperature (VAT) signal high
    55 No or low (under 7.5 V) Key Power to PCM pin 5
    56 Vane Air Flow (VAF) or Mass Air Flow (MAF) sensor high
    Transmission Oil Temperature sensor too high
    57 Intermittent in Park/Neutral/ Switch or Neutral Pressure switch circuit
    1990 Scorpio - Octane jumper installed (information only code - to inform you if it is installed or not)
    58 Idle Tracking Switch (ITS) signal problem
    Vane Air Temperature (VAT) sensor out of range or open
    59 AXOD 4/3 circuit fault
    3.0L SHO - Low speed fuel pump circuit problem
    Transmission 2/3 shift problem
    1990 Scorpio - Idle jumper installed (information only code - to inform you if it is installed or not)
    61 Engine Coolant Temperature (ECT) sensor is or was too low
    62 AXOD (KOEO only) 3/2 circuit short to ground
    AXOD (KOEO AND KOER) 4/3 circuit failure
    E4OD excessive converter clutch slippage
    63 Throttle Position Sensor (TPS) signal too low
    64 Intake Air Temperature (IAT) or Vane Air Temperature (VAT) signal low or grounded
    65 Check intermittent HO2S (signal or ground)
    (R) E4OD truck - cycle OD cancel switch after engine ID is received
    1984 3.8L ONLY - O, M Battery voltage high (check for electrical system overcharging)
    66 Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low
    Transmission Oil Temperature (TOT) signal low (possibly grounded)
    67 Park/Neutral circuit fault
    Transmission Manual Lever Position (MLP) sensor circuit
    (M) Intermittent Park Neutral Position (PNP) sensor fault
    68 Idle Tracking Switch (ITS) circuit (possibly grounded)
    Vane Air Temperature (VAT) sensor out of range or grounded
    3.8L AXOD -Transmission Temperature Switch (TTS) open
    Electronic Transmission - Transmission Oil Temperature (TOT) sensor was overheated
    69 AXOD transmission (O) 3/2 switch closed (possible short circuit)
    AXOD (M) 3/2 switch open (poss short to power)
    E4OD 3/4 shift problem
    70 (M) 3.8L AXOD - Data link to instrument cluster fault. Service any other EEC codes, erase memory and retest.
    If code is still present refer to instrument cluster diagnosis manual.
    71 (M) 1.9L TBI, 2.3L TBI, 2.5L TBI - ITS signal was grounded when throttle should have been opening ITS
    ISC motor problem or Idle Tracking Switch (ITS) signal wire shorted to ground
    (M) 1.9L MFI - PCM re-initialized. Possible electrical noise, case ground or intermittent VPWR problem
    (M) 3.8L AXOD - Data link to instrument cluster fault - See code 70
    72 (R) No MAP or MAF change in "goose" test - retest, check for frequency or voltage change
    (M) 1.9L MFI - VPWR circuit to PCM was intermittent
    (M) 2.3L T/C - PCM re-initialized. Possible electrical noise, case ground or intermittent VPWR problem
    (M) 3.8L AXOD - Message center data link circuit fault - See code 70
    73 (O) Rerun test, if 73 is still output replace TPS
    (R) No Throttle Position Sensor (TPS) change in "goose" test. Must get at least 25% throttle rotation
    74 Was brake depressed after engine ID was received ?
    Brake On Off (BOO) signal open or short to ground
    75 Brake On Off (BOO) signal shorted to power
    76 Vane Air Flow (VAF) did not respond to "goose" test
    77 System did not receive "goose" test - see TESTS
    78 (M) VPWR circuit to PCM was intermittent or the PCM is bad
    79 A/C is on or pin 10 is shorted to power
    80 SERIES CODES GENERALLY ARE CIRCUIT PROBLEMS THAT COULD BE WIRING, RELAY OR SOLENOID RELATED.
    ONLY ONE OF THE CIRCUITS LISTED UNDER THE CODE IS USED ON EACH VEHICLE. THE FAULT IS IN WHICHEVER SOLENOID OR CIRCUIT IS PRESENT ON THE VEHICLE
    81
    Boost control solenoid
    AIRD solenoid
    3.0L SHO - Inlet Air Solenoid
    82 2.3L TC - Fan Control wire shorted to ground
    AIRB solenoid
    3.8L SC - Super Charger Bypass Solenoid
    83 High Electro Drive Fan circuit fault
    EGR Control solenoid
    3.0L SHO - Low Speed Fuel Pump Relay circuit
    84 EGR Vacuum Regulator
    EGR cutoff solenoid
    EGR Vent solenoid
    85 2.3L T/C Automatic - 3/4-4/3 Shift solenoid
    CANP solenoid (ALL 1989)
    (M) 1.9L MFI - System has corrected rich condition
    86 2.3L or 2.9L Truck - A4LD 3/4 shift solenoid
    (M) 1.9L MFI - System has corrected lean condition
    87 (O) Fuel pump circuit fault (check inertia switch)
    Vehicles with 2BBL carb - Temperature Compensated Accelerator Pump Solenoid
    (M) intermittent in fuel pump primary circuit
    NOTE: On some Escorts with automatic seat belts this code is normal IN MEMORY due to the wiring
    88 Throttle Kicker Solenoid
    Variable Voltage Choke relay circuit fault
    Fan Control circuit fault
    A4LD - Converter Clutch Override solenoid
    Electronic Ignition - IDM, DPI or spout circuit fault
    89 A4LD - Converter Clutch Override solenoid
    AXOD Torque Converter Control solenoid circuit
    Exhaust Heat Control (heat riser) solenoid circuit
    90 SERIES FUEL/AIR INJECTION CODES ON VEHICLES WITH DUAL OXYGEN SENSORS REFER TO THE LEFT OR FRONT SENSOR. EXCEPT: 1984-1988 3.8L ENGINES: RIGHT SENSOR
    91
    (R, M) System running lean
    Transmission SS 1 circuit/solenoid problem
    92 (R) System running rich
    Transmission SS 2 circuit/solenoid problem
    93 (O) Throttle linkage binding or bad ISC motor (R) HO2S not reading
    Transmission TCC circuit/solenoid problem
    94 AIR system inoperative
    95 (O) Fuel pump: open, bad ground or always on
    (R) AIR not Diverting (AIRD)
    (M) Possible bad fuel pump ground or open between fuel pump and pin 8 at PCM (Fuel Pump Monitor signal)
    96 (O) Fuel pump monitor circuit shows no power
    (R) AIR Bypass (AIRB) not working
    (M) (Service 87 code first if present) Fuel pump relay or battery power feed was open
    97 E4OD OD cancel light circuit failure
    98 (R) Did not pass KOEO yet (Get 11 in KOEO first)
    Transmission EPC circuit/solenoid failure
    99 (R) ISC needs to learn (Let idle for 2 minutes; Erase memory and retest)
  12. OldFox
    OK, here is a picture of my Ford adapter. It is a female and plugs into the pictures that Hobo is showing. It should be included with the Big 3 connectors that come with your unit. As I said before, this is the only adapter I ever used on Fords and had never seen the 2 wire one shown in the PDF that I posted.
    That PDF was scanned from a manual that was printed in 1985. It may well be that it was an early adapter and the one I show below came out later. I believe it is a universal adapter that may have been introduced later. I think it will serve your purposed if it is included in the unit that you buy.
  13. crownvictoria
    southern Germany
    Wow!
    thanks a lot for all the Information provided!
    All of it is extremely useful. I did not check for this connector yet, it´s too cold outside...brrr...:xmas:
    but I will do within the next few days.
    So when I got it right, I will not need a scanner to read out the failure codes on my crown vic. A regular test lamp is sufficient, so maybe I should give it a try.
    Anyway, I will keep you updated about the scanner tool, as the offer is not too expensive, I believe it would be better have one instead of having none...:scratchchin:. At least it may serve me well with my TS or the Windstar...
  14. Silvertwinkiehobo
    What year Windbag do you have?
  15. Slidemanic
    Slidemanic Well-Known Member
    Northeastern USA
    Did you get one? I'd send you one for free,it is Ford-specific EEC IV and comes with the manual. It was useful on my '85-'86-'88-'89 Ford 5.0L wagons. I have it right here.
