  1. Stormin' Norman
    Make your own Shunt resistor with a wire
    This is pretty straight-forward. If you are using the Ford ammeters without having taken the underhood harness (specially shunt wire) you can do this:
    http://www.reuk.co.uk/print.php?article=Make-a-Shunt-Resistor.htm
    The other links, 2 posts above, say that the shunt should be around .025 milli-ohms for a 50-70 amp ammeter range.
