'67 Squire
Discussion in 'Station Wagon Projects' started by Badwagon, Jan 29, 2015.
  1. Badwagon
    Badwagon more wood plz
    Regina SK
    Not a lot to update you on.. done with the frame until I can fit the front end, so I cleaned it up and prepped it for paint/undercoat.
  2. Badwagon
    Regina SK
    coat #1... I know this is boring and no one cares... but I took the picture for the build and youre just gonna have to look at it.. so :p
  3. Badwagon
    Regina SK
    Front suspension back in.. and its on wheels again. starting planning out the steering, I'm thinking of ordering a steering joint to adapt from the OEM shaft to the crown vic double D shaft.. [​IMG] The car still sits slightly uphill.. even with the smaller diameter tires up front, but that should level out after all the weight is back on it. [​IMG]
  4. Badwagon
    Regina SK
    So... I made a hole... for things to drain back into the oil pan..
    discovered the flywheel I got with my transmission wont work because I have a 6 bolt crank.. that makes me less than impressed.. more $$$ I didnt want to spend..
    and after much frustration.. realized the engine and trans will NOT go into the car in one piece because I have A/C
    soooo I dropped the trans and bolted this lump in..
    [​IMG][​IMG]
    Next concern is bellhousing clearance on the A/C.. Might make the decision to keep A/C pretty easy after all...
    I'm hoping to fit the transmission tonight so I can make a big hole in the floor..
  5. KevinVarnes
    I see what you did there. Are you going to keep it stock to get it up and running first or just go for it all from the start?
  6. Badwagon
    Regina SK
    The megasquirt base map has already been done on the motor while it was in the parts car. So really all I'll need to do is fine tune the map for timing and fuel taking boost into account.
    So yeah.. I'm going to do it all at once but start tlit off at a moderate 4-5psi and tune from there.
  7. Badwagon
    Regina SK
    Not a lot to update tonight... the flywheel DOES work.. I'm just "special"..
    Attempted to bolt in the transmission...
    and Ya I need to open up the tunnel a good amount... that's for another night.
  8. Badwagon
    Regina SK
    Sorry for the lack of progress folks... hopefully I can get some time at it this week.
    Stripped the carpet out..
    It was made in Canada. ..
    Marked out the first of the cut lines..
    Eeek!!!
    Test fit the transmission and we still weren't "there"
    So it looks like I have to lose the factory A/C
    Removed the entire air box... and have to make up some patch panels after I test fit the transmission as is..
    Oh and I also removed Ford's version of hi-fidelity sound circa 1967
  9. MISquire67
    MISquire67 Member
    Detroit, MI
    Awesome!!! Wayyy more work than I'd be willing to do but its coming along great! We have almost identical cars, yours being way higher optioned than mine. Yours is Dark Moss Green correct? Great to see what that color is supposed to look like.
  10. Badwagon
    Regina SK
    Thx man, but I know it as only green lol
    On to the minor update..
    She FITS
    It bloody well should fit since I sliced the poor girl up
    I'm happy the tunnel won't have to go as high as I thought.. and that the rest of the driveshaft tunnel should be OK
    Just have to build a transmission mount..
    Oh.. and I brought home a little "motivation"
  11. MISquire67
    MISquire67 Member
    Detroit, MI
    Looks like thats from a cummins Ram pickup....
  12. Badwagon
    Regina SK
    Indeed it's a Holset He351ve off a 6.7 Cummins
    MISquire67 likes this.
  13. Badwagon
    Regina SK
    Well updates have been and far between lately.. mostly because V1 of the transmission x-member sucked and ended up being cut out..
    NEW plan...
    sourced some off the shelf poly bushings for a Jeep track bar..
    built a full width mount..
    and used some tabs I had from an old universal 4 link kit to FINALLY get the TR-3650 bolted in... sorry for the crappy picture..
  14. n2fordmuscle
    Jasper, GA
    Great work! Looking great and thanks for the updates!!
  15. winged one
    winged one Well-Known Member
    Michigan
    This is amazing to read. What is the status?
