Tires for 1989 Buick Electra Estate
Discussion in 'General Automotive Tech' started by brishay, Sep 23, 2012.
  1. 66mopar wagon
    66mopar wagon New Member
    okanagan
    I have 14s on my monaco and I dont see what your talking about, my car is as big as many wagons and they run great handle great Whats the difference?
  2. Fat Tedy
    Just try it (your wagon) on 15's, then you'll know...................:)
  3. RatMaster
    RatMaster Well-Known Member
    London Ontario
    ah the unobtainium buick/olds turbine center caps
    I got four that look like this
    they use to look like this
    they looked like this when I first got em
    then last year I used the corvette caps and chrome lugs, looked awesome
    and last friday I put new 225/75 r15 white walls on my wagon
  4. brishay
    brishay New Member
    Port Hardy
    Jealous of the condition of those rims. I gotta figure out how to clean mine. I like those T/As the poster above you showed off as well.
  5. MikeT1961
    With these heavy wagons, I would be more tempted to look at a light truck tire than a Radial T/A. The T/A is only 'S' speed rated. We used to run them on Ma's Volvo 240. If you don't need real snow tires, I would look at the Nokian Rativa. The Canadian distributor for Nokian tires is Kal Tire. No worries about needing snows. They are an all weather tire, not an all season, and carry the 'mountain/snowflake' symbol for winter use. They are not overly loud, wear quite well, and have the weight rating for a big wagon that is fully loaded. They are, I believe, available in the 235/70R15 size.
  6. brishay
    brishay New Member
    Port Hardy
    The T/As are for the classic bias ply/street rod look, and Coker makes a whitewall version as well. I like the white printing look on the non white walls and the sidewall profile. They'll be strictly a summer show period tire though
  7. BlueVista
    Northeast Ohio
    The S rating is 112 MPH, that isn't fast enough??
    Unless it's some sort of race car who in their right mind goes over 112 mph in their station wagon???:rofl:
  8. 81X11
    81X11 Well-Known Member
    Round Rock Texas
    I've had really good luck with Radial T/A's, but then again I live in Texas so don't have to deal with snow and ice either. He's my quick ad for them.
    Have run them on everything from my 81 Citation X-11 to my S-10 pickup, 89 Custom Cruiser to my 86 Caprice sedan to our 96 Suburban conversion. They wear well and ride smooth.
    I'm planning to put a set on my new 92 Customer Cruiser soon. (y)
  9. Fat Tedy
    Radial TA's are a good tire, had them on several cars myself amd am running them on the 83, but good for nothing in winter around here. A good winter tire or as Mike put it (we both meen the same thing) a all weather tire with snow flake and mountain is what you want. My honeys mini van, BFG All Terains come with snow flake and mountain, The Goodyear Wranglers come with snow flake and mountain and I'm sure there are many other good winter/all weather tires. I'm just giving my 2-bits because I know the conitions Brian will be driving in this winter, the car he will be driving, and myself have found the winning combo for our west coast winters:D
  10. csosteve
    csosteve New Member
    spencer wv
    i want to go tall and wide on my 93 caprice wagon, without cutting wheel well, thinking 60 series in 15 inch rim. how tall could the rear handle? got 7'' american racing rims on all corners.
  11. 200OZ
    200OZ Well-Known Member
    Farmington, New York
    A 60 series will be too short for anything that will fit your wagon. A 255/70R15 is about as big as you can safely go, but the 7" wide rim might be a tick narrow for a 255.
    235/70R15s look good on our whales imo.
    Mike
  12. csosteve
    csosteve New Member
    spencer wv
    thanks 200oz, beautiful rm, will 8'' rim fit under the rear
  13. MikeT1961
    I prefer an H speed rating (230 km/h or 140 mph) because of the stronger carcass. it is able to deal with heat better, which helps when loaded. If you want one tire for all conditions, and with a car that size, I would give a look at the Nokian Rativa. It is all weather rated, including the mountain/snowflake, and is a light truck tire. The tread is excellent, and they are not over noisy, especially when you consider the capability.
  14. 200OZ
    Yes, an 8" will fit, I know a few guys running 10" rims with 275mm wide tires on there '91-'96 B body GM wagons. You need to get the back spacing on the rim right, but that's what's possible. I have 18" x 8.5" rims, running 255/55R18 on all 4 corners on my RMW with minor rubbing issues up front at full lock.
    Mike
