Olds 307 to Olds 403 engine swap info please?
Discussion in 'Station Wagon Lounge' started by 81X11, Jun 27, 2011.
  1. MikeT1961
    Here in Ontario, if it had a cat when new, it has to have one now, period, smog test or not, and Nora always had 2. You will find that if you go to a full, true dual exhaust it will run better and get better mileage than a single with a Y. Just make sure you use an H or X cross over. That does fit under these Cutlasses, because I've seen my exhaust guy do it.
  2. 81X11
    81X11 Well-Known Member
    Round Rock Texas
    To do true duals I'd need to either notch the transmission crossmember or replace it with a custom one. To stay conpliant for inspection I'd have to have dual cats. It's just too much money. Will be doing a single new free-flow cat, y-pipe to two Turbo mufflers, and exhaust out like stock 442/Grand National behind the rear wheels.
