My Daddywagon
Discussion in 'Station Wagon Projects' started by nelzltdwagon, Sep 12, 2013.
  1. Silvertwinkiehobo
    Holy schamoly, I have never seen a Fox wagon with wheels like that!!! Goes to show, someone's always looking to build a better mousetrap! As for the 351W, don't worry, you can still do it and use the EFI; you only need a truck lower manifold, 5.8 Lightning with a GT40 upper, or a standard truck lower and an aluminum adapter with the Mustang upper, and a properly-flashed computer.
  2. Jairus
    Jairus Well-Known Member
    Salem Oregon
    Read through this thread and you did everything (Cool stuff too!) outside and on the driveway. :mischeif:
    Neighbors must LOVE you! :162:
    But I love your wagon and did some art for Hot Rod years ago suggesting just what you did accomplish IRL!
    Nice rod.
    Grizz likes this.
  3. nelzltdwagon
    nelzltdwagon Well-Known Member
    Thanks! It's raining today, so I could really use a garage. But I am fiddling with my mustang anyway and may do some things on the wagon. Neither rain nor sleet nor dark of night...
  4. pvan
    pvan Well-Known Member
    Michigan
    I had a set of old, rusty Crager SS wheels blasted and powder coated for my Commuter. Very pleased with how they turned out.
    Grizz likes this.
  5. nelzltdwagon
    I really like how those turned out. I am definitely gonna have a set powdercoated white. Time and money...
  6. pvan
    Michigan
    Thanks. I almost didn't bother with them because they looked pretty rough, but after a harsh blast by a pro and a coat of pretty much Wimbledon White, they should be a nice match to the roof after paint.I think I paid $120 for the blast and $160 for the powdercoat. I could have just painted them with rattle cans to save money, but this will hold up much better. Also, it goes on much thicker and hides probably 90% of the pitting.
    Keep them clean and shining, and nobody'll be the wiser.
  8. nelzltdwagon
    Slowly but surely.
    ModelT1 and Grizz like this.
  9. KevinVarnes
    Build looks pretty nice overall. Are you planning on sub frame connectors?
  10. nelzltdwagon
    No. Not at this point anyway. There is not enough power to justify subs. Another problem is the park brake system runs across the width of the floorpan. I have a strut tower brace that I might throw in there. There is a 4 point k member brace under there already.
  11. nelzltdwagon
    Fuel tank arrived today.
    ModelT1, pvan and Grizz like this.
  12. KevinVarnes
    F2C? What fuel pump are you going to run?
  13. nelzltdwagon
    Its a walbro 255 lph for a camaro I believe. I bought it a couple of years ago. Can't recall exactly or specs or vendor. Walbro gs- something.
  14. nelzltdwagon
    I actually started the car today! It doesn't stay running unless I keep my foot on the accelerator. But this is a huge huge step towards a running and driving Daddywagon.
    ModelT1 likes this.
  15. Silvertwinkiehobo
    It has to learn idle, so you have to let it run for a while, and then start it every day, at least once a day. If it won't pick up the idle map, you'll need to diagnose the Idle Air Controller...or at least look to see if it's plugged in....:rolleyes:
    ModelT1 likes this.
