My 1964 Pontiac Catalina Safari build
Discussion in 'Station Wagon Projects' started by justintiime, Sep 28, 2015.
  1. justintiime
    justintiime Active Member
    Been awhile since my last update...I've been showing this car the last few weeks :)
    The car is finally home in my garage next to my 800HP 3rdgen lol
    Next day I loaded up and head south the Pigeon Forge, TN for the annual Pontiacs in Pigeon Forge charity car show for St. Judes
    This cover is for a VAN lol
    Here my car is being filmed, and I will be interviewed to be on the Lokar Car show airing in August :)
    At this show I won third place out of all Modified Pontiacs, and won Peoples Choice out of about 250 cars!
    Window tint was installed after I got back from the show
    The next week I loaded back up, and this time headed back home to Syracuse, NY for the annual Six Nations Pontiac Club show. Its held at the Bill Rapp dealership, where I test drove my first new Pontiac when I was 16. It was a 1998 Medium Blue Metallic WS6 Trans Am. God I loved that car! Couldn't afford it though
    This show I wont first place in Modified Pontiacs and Longest Distance Travelled :)
    The car is probably 95% Done. It runs great. I've purchased a 4 core radiator to install. It runs about 210 with the AC on, and I'd like it a little cooler. I've also decided to install a Richmond 5 speed. I need a steeper first gear to get this boat moving, and I'd love an extra highway gear. I probably won't have any updates for awhile. I hope you guys liked following this build....it was a fun one! :)
  2. OrthmannJ
    Man, it sure turned out nice. I am glad to see you are out enjoying it and sharing it with others.
    It's been quite a transformation from page one to here.
    Well done. Enjoy it.
  3. Thirsty islander
    Windsor, Ontario, Canada
    Just read the full post!! Two thumbs up and looks fantastic
  4. flyingethan
    flyingethan Flyingethan
    Oklahoma City
    Man, if you make this into a manual 5 speed I will seriously be jealous.
  5. justintiime
    Been a long time since I posted!!
    I have fixed a few things with the car:
    1. The original 4 speed had a horrible 1st gear ratio for my 3.23 axle gears. I ordered a new 4 speed from Auto Gear in Syracuse, NY. It is their specialty, and they can order custom gearsets. They put in a much more suitable 1st gear, and a proper speedometer gear so now I can take off from an incline, and my speedo works.
    2. The car overheated on the highway. The cheap Chinese Champion radiator was replaced with a Cold Case radiator and all is well.
    3. My fuel gauge has been repaired. It had a bad ground.
    Latest issue is if the car idles too long, there is no airflow to cool the inline fuel pump. It overheats and the car shuts off. Need to research either a better inline pump, or do an in tank pump, since aftermarket tanks are now readily available (go figure).
    I am still having a blast with this car. it turns heads everywhere!
  6. jmt455
    jmt455 Well-Known Member
    SE Michigan
    justintime, that car is gorgeous and your improvements are spot on.
    Congratulations.
    Carry on!!!!
  7. OrthmannJ
    Glad to see you're back!
  8. Silvertwinkiehobo
    That's interesting that your pump overheats, as modern gerotor pumps are cooled by the fuel flowing through. So, do you have a gerotor pump, or the old reciprocating pump design that are headaches anyway? Also, does your system have a return line, so that excess fuel goes back to the tank, instead of the pump pushing against the regulator? And how do you filter the fuel?
