Going from a 3.8 to a v8
Discussion in 'General Automotive Tech' started by jlr0412jde1024, Jan 15, 2010.
  1. cadipacer
    cadipacer Well-Known Member
    louisville Ky
    Since I only own AMC/Ramblers and have done 17+ swaps of some sort, then we can assume that GMs are easier.. ( I'd hope) so,, engine mounts to crossmember compatiblilty (find on Mailubu site), will the tranny bolt up to newer V8? Which side is the altenator on? ( wiring length is Ok, or not) use same Alt but w/ V8 bracket ? Oil pan arrangment I assume is rear sump?( or same as V6)? Radiator from V6 with AC might be big enough ( check quarts cap of both).. you will need a 6-7 blade fan with a shroud. Make sure radiator is in the same location as the V8 ( distance from core support)or you might run out of room with the longer V8.. You might be come up short on the tranny kickdown (if mechanical) adapt and overcome -fabricate!. V8 Exhaust should be avail. for year application.
    All this above should be common knowledge at a Chevy site of your choice. :tiphat:
  2. Safari57
    Safari57 Well-Known Member
    Vancouver Island, BC
    I can only respond with experience swapping in a V8 from the original I-4.
    Here's what had to be changed:
    Engine mounts and had to consider hood clearance to aircleaner as well
    Swap to bigger Rad and mounting bracket/placement
    Bigger fan - pre electric fan but may require a larger one of those
    front coil springs
    trans and had to add additional trans cooler
    shifter
    longer speedo cable
    drive shaft - shorter
    trans mount had to be moved and if a manual the shifter location and clutch linkage
    longer engine required some frewall mods
    wiring for Alternator, sending units for gages and starter had to be lengthened
    After the swap we came to the conclusion that the best solution was to go to a wrecking yard and buy from a wrecked same body style with a factory V8. Get all the components and save yourself a ton of work and hassle Get everything including hoses so you know what to buy new to actually install. That way you are sure it will all fit the first time. And replace the flywheel/throw out bearing or the flex plate if auto while it is apart and easy to do.
    Barry
  3. jlr0412jde1024
    jlr0412jde1024 New Member
    COlumbus ohio
    To cadipacer
    Thank you for that information i will definately give that a try and see what all happens i am trying to put the v8 in this week coming up.
  4. the Rev
    ...someone took their 'smartass pills' today....:rofl2:
  5. Blackfoot
    Blackfoot Wagonless Soul
    Clymer, NY
    The 3.8 Chevy motor is a 229 ci 90 degree V6, it is a small block Chevy with 2 cyl cut off basically. The only thing you will really need to change for it to drop in will be the fan shroud. Everything else id the same, from motor mounts, tranny, wiring etc...
    Front springs will be a little weak and it will look nose heavy. But if you want to lower it or have that ass in the air look, its already done with no work, lol.
  6. HandyAndy
    like I need a pill...:D
  7. the Rev
    :biglaugh:
    ...jlro????.....i think i'll cal you J....much easier:)
    the one thing that i know of...if i remember correctly...the actual motor mount steel pads...on the cross member...they have to be moved for the v8...but i think the holes are there in the Xmember.....and you have to change the tranny Xmember to ...i think...
    ...its been about 16 years since i did that swap:yup:
    oh...and plz take the time to do an intro(y)
  8. silverfox
    Chevy stuff swaps out easily. Why not drop a 350 in there? :D
  9. Blackfoot
    Clymer, NY
    Nope Rick. The motor mounts are in the exact right spot if you swap a 3.3, 3.8 or 4.3 degree V6 Chevy for a Chevy V8. Don't even need to pull the tranny out to do it, though I would myself for ease. 3.3(200), 3.8(229) Chevy and the 4.3(262) are the only 3 Chevy V6 motors that will accept a direct V8 swap with only the fan shroud needing changed. Every other thing in the car will hook right up with no mods or part swaps needed.
    I did a 3.3 to 350 swap on my '79 Malibu 3 speed on the floor. Helped a buddy do his 3.8 to 350 swap on my buddies '84 Monte Carlo and a 4.3 to 406 in my cousins '91 S10 pickup.
  10. Safari57
    What tranny is in these cars? I had it in my head that they were a tiny trans not up to the torque of any V8.
    This is the weekend the swap was being done right? It will be interesting to find out how it went.
    I remember the days when we'd drive the car home Friday after work and then tear in to it, needing to have it ready to commute back to work on Monday. A weekend of mad thrashing with a tremendous amount of hope that by some time Sunday afternoon it would be ready for a test drive. There were a lot of Monday's when I needed to get a ride to work :rofl2:
    I don't miss those days. I miss the camaraderie, but not the anxiety that went with the program.
  11. the Rev
    well Scotty..your probably right....im old and it was long ago...so i fold:rofl2:
    SAF...i know what you mean...those were fun days:D...now i'm just giddy if the car starts in the mornin:rofl2:
  12. dotcentral
    dotcentral Active Member
    charlotte, nc
    If you are still researching this swap, check this site out: http://www.maliburacing.com/forum/
    Should be plenty of threads to read, don't know what vehicle you have, but plenty of that era Mailbu had a 229 V6 and have since been replaced with 305's and 350's..
  13. silverfox
    IIRC...that 81 bu with the V-6 has the TH200 tranny in there. They CAN be built but...if I was going with a 305 (which I wouldn't because I would go with a 350) I would sure change the tranny right along with the engine.:D
