Custom Chevelle coupe/wagon Frankenstein
Discussion in 'Station Wagon Auctions, Craigs List and Other Stat' started by m261398, Dec 2, 2010.
  1. m261398
    m261398 Well-Known Member
    Gulf Breeze FL
    Apologies if this auction has already been posted:
    http://cgi.ebay.com/ebaymotors/Chev...cbbQQitemZ120651791547QQptZUSQ5fCarsQ5fTrucks
    The idea is almost like the Hot Wheels GTO "wagon", however, this one looks to have the entire wagon rear body grafted to a coupe, rather than just a wagon roof attached to a coupe. Looks like a pretty good job, just that the 68-69 Chevelle side window shape makes it look a little awkward. Also, I didn't look close enough to see if it has the 112-in coupe chassis, or the 116-in sedan/wagon chassis.
  2. Krash Kadillak
    Appears to still be on the 112" chassis. I've see a couple of these now (or it may be the same vehicle, just re-done) You're right about it looking odd. Too bad they didn't start with a '70 - '72 hardtop. The different-shaped side glass on those would have made it look a lot better. This one looks like it's got a lot of money invested in it - especially the interior.
    For me though, it would be a no-go for the odd way it looks.
    EDIT: Took another look at the photos. Now I'm not so sure about the wheelbase. It might be the wagon frame. Hard to tell.
  3. m261398
    Gulf Breeze FL
    Just relooked at the description, and it said it started out from a coupe. At first I thought it could have gone either way, perhaps the side sheet metal from a coupe put on a wagon. But the description suggests it's what I thought; a wagon rear end attached to a coupe.
  4. VTWAGONLOVER
    Essex Jct., Vermont
    I know someone worked really hard on this car, but for me it's a FAIL... I can't get past the windows and how nothing lines up... I'm a huge fan of making 2 door wagons, but for me - this one missed...:disagree:
  5. HandyAndy
    I'd have no problem driving that around the neighbourhood.
  6. goatwgn
    goatwgn Member
    Chesapeake Va.
    I agree with this. I think the best way (from an appearance standpoint) is to take a 4 door wagon (finding these isnt easy-therin lies another problem-availability) remove the center post, mount a 2 door sedan door, and use the front part of the 2 dr sedan quarter grafted onto the wagon quarter. Availibilty of parts, and chopping up decent rare cars is a major holdback on all these mods, however.:)
  7. waygun
    waygun Well-Known Member
    Kingston,Ontario
    Ok..that thing is ugly--as in Frankenstien ugly.
    The lines are just wrong.
    What waste of a good wagon to build that crap.
    What's next?
    The remains of the wagon is being converted into an El Camino??
  8. Bigbarneycars
    SE Michigan
    FAIL:slap: AH LITTLE AUKWORD:slap:IT MISSED:slap:THAT THING HURTZ MY EYEZ AND I'VE BEEN AH CAR GUY ALL MY LIFE:rofl2::rofl2::rofl2::banghead3:
  9. tbirdsps
    Just so nobody forgets I'll attach it so it will be here in perpetuity.
  10. m261398
    Gulf Breeze FL
    Here's what that might wind up looking like.
  11. Krash Kadillak
    Thought about doing that years ago, but doing it with a '77 Ranchero and LTDII. Did a drawing of it and yeah - came out pretty much looking like that Chevelle - odd.
    You're also going to have major problems with frame flex, unless you add a lot of reinforcement (= more weight).
  12. VTWAGONLOVER
    Essex Jct., Vermont
    Oddly enough - I kind of like the 4-door El Camino. That's a cool concept, but you're right - with no real frame it could be structurally "challenged"...
  13. Krash Kadillak
    Those Chevelles do have a full frame underneath. I'm just saying that with it stretched out by a (approx) 36" longer wheelbase, there's going to be a lot of flex in it - could even distort the body if you run it over some big dips or railroad crossings.....
  14. VTWAGONLOVER
    Essex Jct., Vermont
    Yup - I stand corrected. It was the later Chevelles that were unibody. I would think with a full frame it would be pretty solid. No different than a limo stretch really.
  15. Krash Kadillak
    The frames on full-frame cars arn't made with the high-strength steel that you'll find in a lot of areas on a unibody car. Those full frames actually are able to flex quite a bit, including twisting. Limo manufacturers know they need to put some additional reinforcements in when they stretch out a full-frame Lincoln Town Car for example.
