Car not Starting
Discussion in 'General Automotive Tech' started by MrMister, May 31, 2013.
  1. WagonKiller
    WagonKiller Well-Known Member
    greenville pa
    absolutely sir so have I
  2. OldFox
    NO, it's pointless not breakerless. Just accomplished in a different manner, either magnetically or optically. Without dwell between each firing, the charge for the next cylinder can't build.
  3. MrMister
    MrMister New Member
    California
    I always called it pointless and people laughed at me.
    Thanks for the correction though. I don't mind being correct and laughed at.
  4. ModelT1
    Some of my comments are pointless! :rofl2:And I get laughed at!:rofl2:
  5. MikeT1961
    Denny, you get laughed WITH, never AT!
  6. ModelT1
    So, what's the point Mike?:rofl2::rofl2:
  7. MikeT1961
    Like you, I am pointless. I also get laughed at.
  8. ModelT1
    MikeT1961 [​IMG] you get laughed WITH, never AT! :D:D:lolup:
  9. MikeT1961
    Okay, so we laugh together, with one another. And everyone else looks at us like we've lost our minds. Sounds about right!
  10. Loren Gene
    Loren Gene New Member
    rapid city SD
    one, is the power wire to the distributor and 2, did you tighten the distributor anchor clamp if not it may have turned the distributor out of time enough to not have any spark, and maybe pop distributor cap and make shure rotors in there ive seen a lot of people space that out putting in distributors if all good there follow power line to distributor back to a inline fuseable link check for corrosion or loose frayed etc I poke 2 pins on each side of inline fuse connect test light and turn on ignition key see if power to it.
