80's GM B body - full-sized spare tire?
Discussion in 'General Automotive Tech' started by TopherS, Oct 11, 2020.
  1. zzzizxz
    zzzizxz Well-Known Member
    Cincinnati, Ohio
    101Volts likes this.
  2. zzzizxz
    Cincinnati, Ohio
    Spare hubcap removed. The round cover screws down, keeping the wheel from rattling around while driving. PXL_20201029_171854301.jpg
  3. zzzizxz
    Cincinnati, Ohio
    Here is the sling in action. There is an attachment point in front of the tire. The sling sits under the spare, and the handle is on the rear. When you pull then handle, it gives you much greater leverage in removing the full-size spare.
  4. zzzizxz
    Cincinnati, Ohio
    This is the jack that is held against the outside by the two wingnuts you see at either end. Large wingnut is holding a bracket over the jack handle, keeping the jack closed. The smaller blue wingnut at the front just holds the front foot in place.
    Just under the jack, on the left side of the picture, you can see where the sling is attached.
    Also seen directly under the jack lifting plate is the bar that goes through the center of the wheel. That is where the round plate screws down, keeping the wheel from rattling around while traveling. (See picture #4 above)
  5. zzzizxz
    Cincinnati, Ohio
    Hope these pictures and commentary helps! Let me know if there's anything else you would like to see more of, and I'm happy to help.
  6. Silvertwinkiehobo
    I actually like GM's redesign of the jacks. I had my '70 Delta 88 fall off once, and that took a few years off my life.
  7. TopherS
    TopherS Well-Known Member
    Portland, Oregon
    Thanks for the pics. I tried to get mine to work with the jack in-place, but couldn't. I need to try it again. Thanks again.
