73 Satellite Waygun Revival
Discussion in 'Station Wagon Projects' started by waygun, Mar 17, 2019.
  1. Silvertwinkiehobo
    The babbitt metal will destroy a caustic soda solution (ask me how I know this), and so will be removed before tanking the block, but if they have a non-caustic hot process, the cam bearings will be left in. BUT, they then should be measured for clearance, along with the cam journals, before reassembly. As for the heads, how old are the heads? If they're mid-'70s or older, I'm sure they could be milled to bring CR back up to where it was before. And Viton seals for the stems are great.
    waygun likes this.
  2. OrthmannJ
    Looks like you have a good plan. I like the "official" before photo of the engine bay.
    waygun likes this.
  3. waygun
    waygun Well-Known Member
    Kingston,Ontario
    The 318 heads are factory original.
    360 heads are mid 70's with tins of miles on them
  4. KevinVarnes
    I always have new cam bearings installed when a block goes in for cleaning and/or machining. It's cheap and there's no better time to do it.
  5. OrthmannJ
    I assume yours is not the poly head "wide block" 318.
  6. Silvertwinkiehobo
    Right, but do they have a thick deck, allowing for milling to raise the CR?
  7. waygun
    Kingston,Ontario
    You assumed right..She is the LA 318
  8. waygun
    Kingston,Ontario
    Yes the 360 heads have thick decks but the cam I am running will not work with the bigger 360 valves.
    I chose a Summit cam for RV/towing with specs similar to a factory 340 car.
    We took apart the 318 heads tonight.
    Lots of carbon and oil in the bowls.
    Valves are toast and I ordered a standard run of the mill 318 valves.
    We decided to stick with the original 318 heads.
    With some massaging they will work just fine in a heavy wagon with a standard transmission.
    With the Edelbrock intake and Headman headers,the name of the game is efficiency.
    I use the Waygun for hauling schtuff and do drive it a lot during summer months including some big road trips.
    I am not building a muscle car,just a good reliable vehicle that will gain 50ftlbs of torque and maybe 25-30 horses.
  9. waygun
    Kingston,Ontario
    I have a set of cam bearings coming just in case.
  10. Silvertwinkiehobo
    If you're sticking with the original heads, that should bring you less problems to deal with, but you can still have great low and middle range torque with the 360 heads, by using an intake and exhaust manifold that are designed for that. The bigger valves would just ensure the engine didn't endure interference from airflow restriction into and out of the cylinders. My Ranchero's 351W cylinder heads have 1.94/1.50(?)" valves (from a van) and large combustion chambers, but don't suffer detonation or a lack of torque under load. If I had been able to afford the machining, I would've brought up the CR and popped in a semi-performer roller cam, in anticipation of my plans to do an SEFI conversion. Now, when I do go to do it, that work will have to be done before the install.
    waygun likes this.
  11. waygun
    Kingston,Ontario
    Made more progress today.. Heads got stripped and cleaned.
    Crankshaft also cleaned and polished.
    Waiting on parts at this point
  12. waygun
    Kingston,Ontario
    I turned my attention to the engine bay.
    46 years ago this wagon got the Ziebart treatment even though she had seen very few winter drives.
    With a jug of parts washer fluid,nylon brushes and lots of rags the undercoating came off revealing the beautiful JY9 Tahitian bronze metallic paint.
    First pic is the before passenger side for comparison.Second pic is the driver's side...
  13. waygun
    Kingston,Ontario
    On areas that are thick coated I use a brass brush lightly to break it up and use more solvent and let it soak longer.
    I finish with nylon brush with no pressure to avoid scratching the original paint.
    HELLO Fender tag!!
  14. waygun
    Kingston,Ontario
    Sooo tempted to empty out the engine bay and go nuts.
    I know the results will make a huge difference when I pop the hood.
    Flywheel is sent in for machining.
    Stay tuned!
  15. waygun
    Kingston,Ontario
    For fellow gumbers crunchers..here's what the tag reads..
    E44 318-2 Barrel
    D14 3-Speed Manual Column Shift
    RH45
    R = Plymouth Belvedere/Satellite
    H = High
    45 = 6 Passenger Wagon
    G3R
    G = 318 150HP(net) or 170HP(net) 1-2BBL 8 CYL
    3 = 1973
    R = Windsor, ONT, CAN
    367878 Sequence Number '367878'
    JY9 Paint Code: Unknown At This Time
    F2Y4
    Trim Grade/Style/Color
    F = F Class
    2 = Vinyl Bench
    Y4 = Gold
    JY6 Upper Door Frame: Unknown At This Time
    705 Date Built: 7 / 05 / 1973
    BO1872 Order Number: BO1872
    JY9 Roof Type OR Color: Unknown At This Time
    C Built For Canada Specs
    22 Radiator Diameter 22" WIDTH
    B41 Front Disc Brakes Some Yrs. Power
    F18 65 Amp Heavy Duty Alternator
    H41 Heated w/ Upper Vent
    J67 Hevay Duty Wiring Harness
    J83 Roof Air Deflector
    M21 Roof Drip Rail Moldings
    M26 Wheel Lip Molding
    M33 Body Side Moldings
    M83 Rear Bumper Guards
    M91 Luggage Rack Deck Lid
    END End of Codes
