5 speed conversion
Discussion in 'General Automotive Tech' started by OldFox, Apr 14, 2013.
  1. awesomee
    awesomee New Member
    Edmonton
    5spd conversions
    well then I guess I've been told! Why would you listen to a guy who had a 'bidness' building hot rods and doing conversions and repairs on exactly this stuff when you can go and learn the hard way? jus' go and get one of them 301 Turbo 5spds and cowabunga dude, you're rockin'. Another sexual intellectual breakin new ground......well named cur
  2. Hanswurst von Plumpskloh
    Bipolarbear hunting lodge
    Mine have been put on hold and awaiting to resume :evilsmile:
  3. scarymonster
    scarymonster Member
    Largo, Florida
    Very good info about the crank pilot holes and the Z bar. Is there any other way to tell if your engine can be both auto and manual without removing the trans?
  4. 1967 Tempest
    NPR, Florida
    You could unbolt the torque converter, and with a very long and small headed inspection mirror, using a very bright flashlight, you MIGHT be able to see if the crank register is drilled.
    The Z-Bar hole you can see from outside the car with no issue. Again, the z bar thing is not a deal breaker as you can go hydraulic. But as said, the hydraulic clutch needs a lot of fabrication.
    Yu need pedals, then the master cylinder for the throw out bearing. Then need to bend the lines to the TO bearing, get the correct TO bearing installed and then make sure that it has enough pedal throw and the MC is big enough for the clutch you choose.
    I am swapping my 67 Tempest wagon over right now. If you have never done it, it will be a challenge. NOT impossible. But a challenge. I would say that for a novice it is a 8.5 to a 10. For an experienced guy or full time mechanic a 4. Mainly because it is time consuming and if you do not have a lift, there is a lot of under the car and in the car back and forth...
  5. Hanswurst von Plumpskloh
    Now and then, the local ALDI here sells endoscopes which can be used for non-medicinal purposes like the one you're referring to:
    [​IMG][​IMG]
