1965 Colony Park tailgate window issue...dash switch
Discussion in 'General Automotive Tech' started by TujungaKid, Jan 22, 2018.
  1. Silvertwinkiehobo
    And as far as the horn, I wasn't aware they had a relay; I thought relays came into play once cruise control showed up? You'll have to check the fuses in the fusebox, and the fuse links under the hood.
    MAK likes this.
  2. Thirsty islander
    Windsor, Ontario, Canada
    Horns have relays but usually under the hood by the horns. You may have dislodged a connector under the dash.
  3. Thirsty islander
    Here is a 65 fairlane rear window
  4. TujungaKid
    TujungaKid Active Member
    Santa Rosa, CA
  5. Thirsty islander
    Apply 12 volts to the terminal that says "to ignition switch" and see if the window works. Obviouly the relay isn't used for the rear key switch thats why it will work.
  6. TujungaKid
    Santa Rosa, CA
    Thanks! did that> bad relay.
  7. TujungaKid
    Santa Rosa, CA
    Got the relay today problem fixed. Now if I can just figure what the heck I did to my horn. I hate electrical issues.
    Thirsty islander likes this.
  8. Thirsty islander
    Great job....next problem please!
  9. MAK
    MAK Well-Known Member
    VA
  10. TujungaKid
    Santa Rosa, CA
    A little help from you guys didn't hurt!
  11. Silvertwinkiehobo
    I'm not the only one who helped, I just provided electric diagrams; all of you who know more than I do, you deserve the credit.
  12. rhoadeschris
    rhoadeschris New Member
    silvertwinkiehobo. hoping you can help a fellow Texan. You mentioned having wiring diagrams that would work for a 65 Mercury Colony Park. My headlights and high beams suddenly stopped working and I'm trying to track down the wiring issue (already replaced the headlight switch that serves as the circuit breaker and the high beam selector switch on the floorboard. so unless all four just happened to go out at exactly the same time I'm guessing I have a wiring issue.)
  13. Silvertwinkiehobo
    Check your PM inbox, I left two messages there.
