1964 Ford ignition switch removal....
Discussion in 'General Automotive Tech' started by adavis, Oct 27, 2014.
  1. adavis
    adavis New Member
    Washington State
    So the back part of my ignition switched popped out today, and I can't figure out how to remove the rest of the switch from the dash so I can replace/repair it. If I push the metal "barrel" from behind the dash it will push the bezel out 1/16" but it doesn't have a clip or anything I can see to remove. Any advice? Its a 1964 Ford Country Sedan. Thanks.
  2. Vista
    Vista Well-Known Member
    Gainesville, FL
    The bezel is threaded like a nut. Note the notches in the bezel to engage a special tool.
  3. adavis
    adavis New Member
    Washington State
    Thanks for the info Vista. Turns out the main thing I wasn't doing is removing the lock cylinder first. The requires a toothpick in the small hole next to the key, and then turning the key counterclockwise....it pops right out. Then, while you firmly hold the bezel on the front of the dash, you push on the "barrel" behind the dash and turn slightly counterclockwise. It came out very easy. Now I just need to figure out how to put the guts back together.....or buy a new switch. THANKS.
