1957 country sedan build
Discussion in 'Cosmetic & Restoration' started by 1930artdeco, Apr 21, 2021.
  1. 1930artdeco
    1930artdeco Well-Known Member
    The inside upper corner has more of a pucker than the outside. If worst come a to worst I can add a dab of sealant. Maybe.
    mike
  2. 60Mercman
    60Mercman Well-Known Member
    Heat may also bring that into shape. But the sealant may also be an alternative. Thank you for keeping us updated. Such a great car.
    OrthmannJ likes this.
  3. 1930artdeco
    Update time: I was finally able to cut/grind/torch or unscrew all of the body mount bolts-that is the next major project. In the meantime I also replaced the rear window gasket, tail light lenses and added a big ass sway bar!
    OrthmannJ and 60Mercman like this.
  4. 1930artdeco
    Good news on the windshield front: trim was saved with no real dents or bends and there is NO RUST!!!!!. Bad news is I lost the windshield getting it out. I put a little too much pressure in one spot and crack…..☹️☹️. So have two questions: 1) should I order online or locally when they install it. And secondly, how do I get those tiny screws out. I have one that was so rusted I had to drill the head off to get the trim off. I can’t get my tiny vice grips on it as there is so little of it left.
    You're not. It'll have to be drilled. Since you said the screw was tiny, is it smaller than 1/4 inch diameter?
  6. 1930artdeco
    Yes it is, probably #8 screw. Looking like you are correct in that I will have to drill, weld and redrill. OR find a slightly larger self tapping I can use-not hopeful but will try.
    Look at metric also, you might be able to find one just a smidge larger.
  8. 1930artdeco
    Update:
    I got all of the body rubber and bolts replaced! I figured out that either this kit fits multiple bodies which I think it does or Ford let this frame go down the line minus two supports. According to the instructions there should be two supports on the inside frame rail with special washers. My car (57 wagon) only has the rear mount and the special washers were in two different places. One-the passenger side-was in the correct location, the driver side was in the first outboard support :icon_scratch: I replaced everything as is the way it came off the car and the doors still line up and shut plus there was no body shift so I figure I will leave it as is. I do have one question though.
    1) The very front bolt-the one that is exposed on the bottom-has a gap between the body and the frame. I replaced everything as it came off the car but I still have a tiny gap. Between the frame and the body there should be a square piece of rubber and a shim. So replaced them but either the rubber is two thin or something else goes in there. I can replace the square piece with the round rubber piece and that will take up the gap for sure as it is really thick. Advice?
    Thanks Mike
  9. 1930artdeco
    Update: new shield is in and I have begun the rewire process. I have a dead line of April now to get her safely on the road so we can go on vacation in her.
  10. 1930artdeco
    yet again.....:slap:
  11. OrthmannJ
    Looks good!
  12. Silvertwinkiehobo
    Upside-down and rightside-up!
  13. KevinVarnes
    Where were you able to source a new windshield from?
  14. 1930artdeco
    I got it from auto city classics. It comes I. From Asia someplace-didn’t look like China.
  15. 1930artdeco
    Update: working the wiring over finally. got the back half done, most of the front is now done and will be headed to the dash next. I am 'hoping' to finish the wiring in a week or two and have a club member help me verify that everything is connected correctly. Then, off to firewall ins., heater box/hoses and welding floor pans.
