Rear lined/thick/panel material?
Discussion in 'Cosmetic & Restoration' started by 63rarewingedgod, Mar 19, 2008.
  1. 63rarewingedgod
    63rarewingedgod lover of wagons
    lompoc, ca.
    Here's a few possibilities. You could email them to ask:
    http://www.originalauto.com/index.htm
    http://www.stockinteriors.com/
    http://www.thetrimconnection.com/default.asp?CT=MainNav
    http://www.fitzgeraldsrestoration.com/restoration_products.php
  3. 63rarewingedgod
    lompoc, ca.
    Thanks. What do you actually call it. Vinyl panel? Side kick plate? Thick coulmn stuff?
  4. Stormin' Norman
    It's more of a rubber/PVC mat I think. You know where you might score is the RV suppliers, too.
    For cars, it's tough to find the material in original colors. One of those first two might be the best place to ask. PVC isn't all that flexible. An impregnated synthetic rubber mat like this guy used on his Falcon chrome is probably the right stuff, but I think it only comes in black.
    Rick's Roof Rack Pad solution (see the mat he used):
    http://www.rickwrench.com/index79master.htm?http://www.rickwrench.com/rackpads.html
    Truckbed liner is similar to the original stuff.
    Last but not least is the H.A.M.B. site. They have a good list of vendors for vintage rubber-floored autos.
    http://www.jalopyjournal.com/?page_id=176
    I still think its worth an email to the first two links I sent, but one guy you might want to ask (PM Private Message) is 'the Rev'. He can probably point you the best source.
  6. Stormin' Norman
    This doesn't have any for the Meteor, BUT Check it out:
    http://www.autotrimsupply.com/make/MERCURY.htm
    You can get the Ford and Lincoln lines here:
    And HERE IS THE MAIN VINYL FLOORING Manufacturer. :2_thumbs_up_-_anima (y) :D
    I checked out the 1965 Mustang Trunk mat brand
    http://www.autotrimsupply.com/eshop/catalog/174560.asp
    and googled to get them here:
    http://www.accmats.com/
    Click the Vinyl icon and check below #59 Blue (y)
    http://www.accmats.com/Products/Flooring/Material.aspx
  7. Stormin' Norman
  8. Stormin' Norman
  9. 63rarewingedgod
    lompoc, ca.
    Man, you awesome!!! That will probably do fine. The only thing that actually looks like what was in there originally. Right down the road too and cheap. Now i have to get some matching OME spray to match. Next thing is to make the third seat from scratch.
    Thanks again.
  10. Stormin' Norman
    Who's awesome now? You're gonna make the seat from scratch? THAT is awesome! I can reupholster, but making a car seat with all the folding stuff is outta my league! Pics when you can. eh?
    Glad you found it! Was is the ACCMAT place?
  11. the Rev
    you found some...which one of the 100 links was it..:idea:
    I looked for it a while back and the closest thing i found was 'running board' material from my vintage supplier?...but i didnt loook real hard:D
    ...and I didnt know Stormin:biglaugh:
  12. Stormin' Norman
    Yeah, was it ACCMATS? It sure looks close to the original colors.
    Rev, I watch a lot of CSI. Not. :biglaugh:
  13. 63rarewingedgod
    lompoc, ca.
    Sorry guys. I meant that the OSH rubber mat was close enough.
    Now that I think of it, might wait to actually check out the links to find something closer. As for colors, i was going to spray it to match. Should take well on that black rubber.
  14. Stormin' Norman
    Is that OSH the same as Rickwrench's pads?
    If you're going to spray it, I'd suggest you use something that can take some wear and tear. Plastic paint gets rigid and has very little UV Ray / Sun light protection. This stuff does. It's about $12.00 / spray can. Get their Prep soap or vinyl cleaner to clean off any factory chemicals before you paint. I did my whole interior with it and it is nice.
    http://www.sem.ws/product.php?product_id=242
  15. 63rarewingedgod
    lompoc, ca.
    Here are some picts of actual material...
    I know i have to clean the back but i'm doing that now.:slap:
