Pickup running on Wood Chips
Discussion in 'Fuel Economy & Emissions' started by Stormin' Norman, Aug 15, 2009.
  1. Stormin' Norman
    101Volts likes this.
  2. Postal
    Postal flcn a
    Green Bay, Wi
    Wood burning truck
    Well if he ain't a "chip off the ol' block"!
    Poison_Ivy likes this.
    Wonder if a big a$$ wagon is more adaptable. Mileage would be per LOG - MPL. Stumpage fees might go up?;)
  4. Poison_Ivy
    It should do plenty more, if the gas gets compressed. The major drawback with these systems is the soot which cakes up the valves. If you could somehow filter that out, you should be left with only clean combustible gas. Having the gas flow through an oil bath could do it
    It's novel, to say the least, but very inefficient. Unfortunately, the engine has to take in the hydrocarbons to run, so filtering wouldn't work. But making a hydrogen gas generator, using wood as the fuel stock, then introducing the hydrogen into the engine, would be an alternative to prevent the sooting of the valves.
