Hello from the rust belt of the USA
Discussion in 'The Welcome Wagon' started by filthy1, Apr 28, 2013.
  1. filthy1
    filthy1 Member
    Hello my 65' Belair wagon has its share of rust including floor pans spare tire well & front body mount supports. Should I repair what I have or are they readily available in better shape?
    Thanks Jim
  2. 1964countrysedan
    Texas
    They are still available here in the south mostly rust free.
  3. 1tireman
    1tireman Well-Known Member
    Slidell, Louisiana
    Welcome Jim. :Welcome:
  4. Bigbarneycars
    SE Michigan
    :Welcome:filthy1. There are probably new floor pans on the market for your '65. If it were a '55, '56, '57 and you had deep enough pockets you could build a new one piece by piece. Check out your after market Bowtie store(y) Jer
  5. ModelT1
    :Welcome:to the forum. Why oh why are members afraid to tell where they are? The government and the trash collector know. "from the rust belt of the USA" This could be almost anyplace not in a desert.:confused::D
  6. elagache
    elagache New Member
    Welcome and reproduction floor pans available.
    Hi Jim and welcome to the Station Wagon forum! :Welcome:
    Always nice to have another 1960s GM long-roof around here!
    I just typed "1965 chevy bel air floor pans" into Google and got tons of hits. This parts are available as reproductions so no fuss and no worry of replacing really bad with - what ain't that good either.
    It depends on your budget, but if you can afford it give your long-roof and extra good does of TLC!
    Cheers, Edouard :cheers:
  7. MikeT1961
    Welcome to the nuthouse we call home! Sounds like you will fit right in! About your question: Yes, there are 65 Bel Air wagons available out there in good shape, but not as many as there are Impala wagons. It seems the survival rate amongst the lower trim levels is much lower than the higher. As long as your frame is still good, or at least fixable, I would put the effort into a car you know rather than taking on another project. That one may well have different, but equally expensive, problems that need dealing with. At least with your own, you know what you have to work with. It also seems a crying shame to give up on a wagon that has managed to survive well over 40 years! Loyalty should be rewarded, if possible. Let's see pictures of the old girl. We're good at spending other people's money, so we'll be GLAD to tell you what to do with the one you have! Good luck and have fun.
  8. AK27
    AK27 Well-Known Member
    Fairview, Illinois
    Welcome filthy1!
  9. Dadstoy
    Dadstoy Member
    Ohio
    Any thing that interchanges with a Impala is avalable. Anything that is wagon specific ,you are going to have to find used or make it yourself. Ask me how I know.
    From the rust belt also.
  10. Dewey Satellite
    Dewey Satellite New Member
    Ogden, Utah
    Welcome to the forum Jim! :Welcome:
  11. fannie
    fannie Well-Known Member
    Nova Scotia, Canada
    :Welcome: aboard filthy1 from the Canadian rust belt. :dancing:
