GM Oil Pan
Discussion in 'General Automotive Tech' started by jase386, Mar 18, 2010.
  1. jase386
    jase386 Hubcaps RULE!
    Greenville SC
    85 Caprice, so i guess im asking anyone who owns an 80s gm full sized box wagon. Do you have to jack up the engine to swap out the oilpan gasket?
  2. tbirdsps
    Technically I know nothing of GM cars but you'd appreciate the extra room if you did jack it up.
  3. joe_padavano
    Northern VA
    Oh yeah! Depending on which engine you have, you often need to properly index the crank so the counterweights are up at the front as well. The reality is that by the time you do everything you need to do for oil pan removal, you're only an engine hoist and a few trans bolts away from pulling the motor.
  4. Bob Scott
    Bob Scott New Member
    St. Louis Missouri
    With the 87 caprice wagon, yes! I'm guessing it's the same, or pretty much as the 85.
    Both engine mounts should be removed at the block and you can jack it up at the crank shaft hub.
    Heck Jase, jack up the horn and put a new car under it! :biglaugh::biglaugh::biglaugh:
  6. low93wagon
    low93wagon New Member
    Wichita
    It would make it SO much easier, that's for sure. As joe said, it would be just as easy to pull the motor out to do the switch. Just my 2 cents.
