68 country squire tailgate questions
Discussion in 'Cosmetic & Restoration' started by tigett, Jan 17, 2014.
  1. tigett
    tigett New Member
    Vancouver WA
    My 68 CS was missing the mechanics of the back window operations for the tailgate. does anyone have pics of the inside tailgate. what years are capatible? I have the motor just not the scissor arms (is that the regulator?) lifting part. I know many years of the bronco's window work the same way, would they work on mine? What about other makes or models. any diagrams? Thanks All
  2. FANTM58
    FANTM58 Active Member
    Denver, Co
    I can get you those pictures .
    Monday if that helps ?
  3. FANTM58
    Denver, Co
    Pictures
    OK I was able to get a few shots of the interior gate area.
    but since i have to do this from inside the wagon , to keep the window
    up and out of the way , mabey not the best ???
    anyway , if there is any other spacific shots needed let me know.
    the rear cover is removed and access is fairley easy.
  4. tigett
    tigett New Member
    Vancouver WA
    Thanks Fant, that helps alot. I'm still looking for replacement parts
  5. Krash Kadillak
    Mechanisms on the big '66-'68 wagons should all be the same. Even the big Mercurys would work. Do not try to use Bronco stuff- different animal (although the workings of the window might be similar).
  6. tigett
    tigett New Member
    Vancouver WA
    What about '65. there is a tailgate window regulator on ebay now. would it work on my '68. I cant find any cross references. what's different? I'm not scared off cutting or drilling holes to make it fit if its possible. Thanks
