Where to find original car speakers?
Discussion in 'General Station Wagon Discussions' started by brainiac, Jan 1, 2012.
  1. brainiac
    brainiac New Member
    Bad front door speaker in 1986 Merc Colony Park. The original is a Ford E5UF-18808-AB. Can't seem to find one online. Suggestions appreciated. Thanks.
  2. BlueVista
    Northeast Ohio
  3. chopt50
    chopt50 New Member
    Pottstown,Pa
    Not that I have anything against OEM parts, but when it comes to anything electronic, using todays technology would be my choice.Especially when it comes to speakers because you don't see them anyway .
  4. Jairus
    Jairus Well-Known Member
    Salem Oregon
    There is pretty much an industrial standard in sizes and mounting. Since all speakers are hidden I think all you need is to find the size and put pretty much anything in there. Else... raid a scrap yard for a parts car! :2_thumbs_up_-_anima
  5. 1964countrysedan
    Texas
    yep what he said I got particularly good at hidden replacements on Miatas
  6. Tanner
    Tanner Member
    Sherbrooke QC
    Hi, you should find a JL-Audio dealer, this is a very good american products
    I work with them at my job, speakers are very good sound and good sensitivity, it's better than OEM speakers. and it's not very expensive, around 120$ / pair of speakers
    you can check products at
    http://www.jlaudio.com/
    http://www.proshopaudio.com/02_02_03.asp
  7. a1awind
    a1awind Tiki God
    Ellwood city Pa
    im with tanner and chopt50
    oem sucks and if you can replace the original with something better that fits...go for it.
    up till the last few years i had never heard a factory audio system that blew me away....except for the ford mach audio 1000w found in the mustang and cobra. as of late ...the lexus systems and lincoln systems are killer
  8. brainiac
    brainiac New Member
    Well, guys, I've got street rods with huge/quality stereos. On this 1986 Colony Park, however, I just want to keep it simple and original. I was able to find a functioning original digital radio and all the speakers but one work. Thus, the desire to locate one working original Ford 6.5 speaker. Thanks for all the input.
    ...now I still need to locate that speaker!
  9. gray07
    gray07 New Member
    michigan city, indiana
  10. djjsc
    djjsc Member
    Saskatchewan, Canada
    Door speaker
    Are you sure it's the speaker? That fat harness entering drivers door is notorious for broken speaker wires. I've had mine repaired twice now. Check continuity first. If you need an OEM speaker, I've got 2; you might want a spare. Doug
  11. Fat Tedy
    I can understand the keeping it simple and origonal, I've kept the stock radios in all my cars. If you were looking for a stock speaker cover that would be another thing, but it's just a speaker your after, You mite find a stock one rite away but chances are not. You can get new ones basicly tommorow.:yup:
  12. MikeT1961
    One of the problems you will have with the original replacement is that the paper cones are brittle so the sound quality is way down. Unless you find one from an 88 or newer Premium or High Level Sound package car, I would go aftermarket. 88 was when Ford went with the polypropylene cones on the high end JBL speakers. I can tell you from experience, they work, they last, and the sound is really very clear, even after all these years. My set (all 6 from an 89 Grand Marquis) are in car number 4. All you need is a good pair of amps. They are high resistance, so are just a little power hungry.
