Vermont Yankee,
Discussion in 'The Welcome Wagon' started by Green Mountain Boy, Mar 23, 2014.
  1. Green Mountain Boy
    Green Mountain Boy New Member
    Albemarle, NC
    Hi from Vermonter moved South. My Station Wagon is a 68 Chrysler T & C I purchased inNorth Carolina from original owner. Exterior has been repainted to original color and am searching for Di Noc material to replace the woodgrain which died a number of years ago. I could use help with that or any ideas to replace wood grain.
  2. ModelT1
    :Welcome:Welcome to the group. Good luck. There have been many threads and information about the woodgrain material. Try typing in the SEARCH and check it out.
  3. 1tireman
    1tireman Well-Known Member
    Slidell, Louisiana
    Welcome aboard!
  4. Krash Kadillak
    Welcome to the SWF, GMB!
    Woodgrain issues, you'll want to check out our specific Sub-section, here:
    http://www.stationwagonforums.com/forums/forumdisplay.php?f=28
    You'll probably need to do some research to find the correct product. Each manufacturer / vehicle had its own type.....
    Glad to have you here....
    Marshall
  5. fannie
    fannie Well-Known Member
    Nova Scotia, Canada
    :Welcome: aboard Green Mountain Boy.
  6. AK27
    AK27 Well-Known Member
    Fairview, Illinois
    Welcome Green Mountain Boy!
  7. the Rev
    :Welcome: GMB
    ...lets see her !!
  8. Longroof79
    Longroof79 Well-Known Member
    Gainesville Fl
  9. MikeT1961
    Welcome to the Nuthouse we call Home. Sounds like you have one GREAT wagon there. The Dy-Noc is a problem for everyone. Good luck with that hunt. You may find it easiest to get a wrap done for that area. Either that or have it painted on. It is not the easiest to do, but done right, it looks great. Plus, being paint, it is not subject to the same damage as the original product. The other advantage to paint is that it can be touched up, carefully, in case of any stone damage.
  10. Dewey Satellite
    Dewey Satellite New Member
    Ogden, Utah
    Welcome to the forum Green Mountain Boy! Great to have you join us. :Welcome:
  11. jrwscout
    jrwscout New Member
    Kansas City, MO
    Welcome aboard! So let's see that fine ride!
