Tubed Mailbu?
Discussion in 'General Station Wagon Discussions' started by ROCK!, Nov 25, 2009.
  1. ROCK!
    ROCK! New Member
    colorado springs colorado
    I've done some searching, and haven't come up with the answer Im looking for. There is one thread here but not quite what Im doing. Any one out there have a tubed wagon with a functional rear seat? I don't mean "mini" tub, I mean a real tub. I don't really want to take mine out because it would be Kool to have a drag car with 4 seats. I will be narrowing the frame, building a 9" for it, and will be running a pretty big tire. I may even move the wheel well back to make sure I get enough tire. Im gonna be sending at least 1000HP to them so there gonna have to be fat. Any of you guys ever see a wagon like this? If all goes well I want it to sit about stock ride height, and have the tire tucked inside the body. Im thinking of running a 32x14 if I can make them fit. I know it will come all the way up to the window and that's fine, I just don't want to expand the wheel base a lot. I've done a few drag cars before but as you know this will be my first Malibu. Its a 79 wagon, and Im building an enormous big block for it.
  2. marcar1993
    marcar1993 Well-Known Member
    CNJ
    You will have to mod the frame, hope you know... Also, I doubt keeping the seats is an option without heavy modification...
  3. silverfox
    I don't see that happening in my mind. But I've seen guys do things I've never thought of before. With 1K HP, tires like that and with a cage you have upped the complexity considerably. But I have to say....that kind of a sleeper is my kind of wagon!
  4. The Stickman
    Lehigh Valley pa
    I am not sure it will fit eaither. You might be able to get away with a narrowed rear bench. If it were the bigger B-Body wagon then yea I think you could do it. Not much room back there to begin with.
  5. Krash Kadillak
    If you had a 3-seat wagon, you could put a couple of big boys back there for good weight transfer........
  6. ROCK!
    ROCK! New Member
    I know I will have to narrow the frame, and probably would be better to just do a tube chassis. Im just trying to avoid taking it to far:rofl2:I plan on doing a 9" rear, and a 4 link to keep things tight and will be moving the fuel cell inside where it belongs. Im also gonna put a wheelie bar on it, I have seen way to many good cars get destroyed because the front end slams into the track. I will be putting some jounce shocks in the front to.
