Towing capacity of a 67 Country Squire
Discussion in 'General Station Wagon Discussions' started by winged one, Aug 6, 2009.
  1. winged one
    winged one Well-Known Member
    Michigan
    Can anyone tell me or point me in the direction, where I could find the towing capacity of a 1967 Ford Country Squire, 390-2v (265hp) without a manufacturers towing package?
    I am thinking of a pop-up, teardrop or other small trailer.
    Thanks!
  2. Krash Kadillak
    If that's all you are towing, you should be fine.
  4. winged one
    Michigan
    Thanks guys I appreciate the input.
    FYI, I just found out the draw-tite and Reese are the same company now.
    Not good for competition, and thus the prices we must pay for sure.
    I can see that. Hybrids can't haul their shadows.:yup: :rofl2: Gonna be a tough market for many big brands, from Spark plugs to big tires.
  6. mrtotty
    mrtotty New Member
    Tonbridge, Kent, UK
    I think you would be fine towing a small trailer with a 390 V8. To be sure, though, wouldn't Ford itself be able to tell you? I don't know how you'd go about finding out though, but there would be someone who'd know.
    Caravanning is very popular here in Europe, and for pulling large vans, most people use saloon cars with 2.0-2.2 litre turbo-diesel engines or small-medium SUV's.
  7. Stormin' Norman
    Just found this too. It lists by brand back to 2005. Yours would be stronger, because it has a frame and is heavier, but the explanations might help with what the sales people try to sell and tell you.:
    http://auto.howstuffworks.com/auto-parts/towing/towing-capacity/vehicle/towing-capacity-chart.htm
    This Towrating database isn't working for me, but it has lots of interesting info.
    http://www.campinglife.com/towrating/
    This is a good guide book:
    http://www.sherline.com/lmbook.htm
    My little Fairmont wagon hauled a small double-deck utility trailer with over 3,000 lbs. from central Mexico to Canada with a stock 302 V8. The roof rack was full, the inside cargo area was full and two adults. I'm sure you'll be fine.
    This article is by a pro on Trailers.
    http://ezinearticles.com/?Tow-Vehicle-Capacity&id=381879
    Here's his site:
    http://rveducation101.com/
    And this one seems pretty good too:
    http://www.towingguide.com/towvehicle.html
    From these articles, whatever you tow shouldn't weigh more than the car. The hitch should be right for the car and the trailer, and your suspension needs to be right for both as well. Also the hitches with 'load-leveller' attachments are only a good idea if you're hauling a monster trailer (Long, Wide and Heavy). They do make the towing safer, but they put a lot of stress on the hitch and car. I've seen them used especially in our Canadian Rockies, where wind gusts can tip a trailer over, and the car, if the load isn't properly distributed between car and trailer. A little teardrop trailer wouldn't need that, because of the low profile.
  8. aswoa
    aswoa New Member
    charlotte nc
    towing capacity
    Ford (motorcraft) published a trailer towing tips and facts. The oldest i have is 1973, most similiar engine was a 400. cubic inch. that was rated as a class two hitch 500 lbs tongue, 3,500 puounds trailer weight.
  9. Ford_Fellow
    Ford_Fellow Well-Known Member
    Prince George British Columbia Canada
    The type of tires you have can make a large difference on towing a trailer...A good light truck tire can cure a lot of side sway....John put them on his Nomad and sure made a difference on towing...Nudder fulla bought a new trailer to pull and it was a little to big and had to sell it and get a smaller one as it wanted to get away on him......Before you purchase something try pulling it first at highway speed and a little above to make sure you are not on the eadge....of disaster....You may want to look at an equilizer hitch also and alowe for how much you will put in the trailer....
  10. Eagle Freek
    Eagle Freek Well-Known Member
    If you don't already have one I would recommend an external transmission cooler. I toasted a transmission pulling a couple motorcycles because I didn't have one.
  11. Stormin' Norman
    Forgot all about that, but you're right on! IIRC, most of the optional Factory Trailer packages from the BIG 3, all offered tranny coolers, after the 1965. Thanks for the reminder.(y)
  12. winged one
    Michigan
    Thanks for the input guys. Greatly appreciated.
    Things have changed though. Not getting the Ford with the 390 now.
    Getting a 67 Country sedan with a 289 (200 hp rated).
    Any input changes?
