Tailgate Window Problem - Help
Discussion in 'Cosmetic & Restoration' started by ivanogburn, Jun 30, 2017.
  1. ivanogburn
    ivanogburn Junior Mint
    Galveston, TX
    The tailgate window on my 1977 Mercury Marquis Colony Park will not raise anymore. It will lower just fine, but will not raise. I can hear the motor running and I can raise the glass by hand, but once raise it wants to fall back down. Since getting to this mechanism will be a bear, can anyone give me some helpful hints as to what could be the cause or tricks to repair?
    Regardless of the problem, you will need to lay the tailgate down and remove the inner cover to find out what is wrong. It could be the motor drive is worn out, or the glass separated from the regulator, but for the problem, you need to access the inside of the tailgate.
  3. ivanogburn
    Galveston, TX
    Yes, already there but as you may know, only spider monkeys or space aliens can easily access the motor hardware!
    ModelT1, Grizz and Poison_Ivy like this.
  4. Poison_Ivy
    Most of them do better work than most mechanics around my area.
    ModelT1 likes this.
  5. Thirsty islander
    Windsor, Ontario, Canada
    I do have a 77 colony park but I have never had the rear panel off. I did have the one off on my 70 country squire and I don't remember it being a particular bear to get to. It had a bunch of things wrong with why it wouldn't work. One was the plastic gear had the inner drive part kinda stripped so I fixed it with epoxy. Two was the wire going through the door jam was broken so had to fix that. The switch was bad and the wire in the harness that feed the back window shorted out under the dash and melted the wire and relay. You can pull the plug at the window motor to see if it's getting power in both directions. From there you will know which way to go.
  6. ivanogburn
    Galveston, TX
    Weather permitting this weekend I will venture into the abyss ....:yikes:
  7. ivanogburn
    Galveston, TX
    Well I took it slow and steady and it still only took me two hours to full repair the power window on my magix tailgate. Thanks to this video
    It is amazing and anyone with window issues should check it out.
    ModelT1 and Poison_Ivy like this.
  8. Silvertwinkiehobo
    Dude, the grease is like Brylcreem--'A little dab'll do you.'
    Poison_Ivy likes this.
  9. VangoatNC
    VangoatNC New Member
    North Carolina
    Do you still have that YouTube link? I seems to have disappeared.
  10. Poison_Ivy
    It's working, for me:
    VangoatNC likes this.
  11. Chevelle427
    Chevelle427 Member
    Just starting on a 72 chevelle wagon.
    Working on gate motor found one at local parts house buy ot did not work so motor num 2 on way .
    Watching this thread
