Sedan vs station wagon?
Discussion in 'General Station Wagon Discussions' started by fannie, Jan 27, 2014.
  1. fannie
    fannie Well-Known Member
    Nova Scotia, Canada
    Does anyone know if the rocker panels on a sedan are the same length as a stationwagon? I am know looking for rockers for Fannie and I'm wondering if the rockers on a sedan would be the same length as a station wagon. I'm thinking it should be but i'm not sure. :confused:
  2. Krash Kadillak
    I believe you could use rocker panels from a 4-door sedan. The 4-door sedans (and 4-door hardtops) were on the same 116" wheelbase as the wagons. You can not use the rocker panels from any 2-door, as they are on a shorter 112" wheelbase.
  3. FANTM58
    FANTM58 Active Member
    Denver, Co
    Not sure of your application , but I was told that on my 68 country sedan
    The Galaxie rocker trim is the same and will fit !!
  4. fannie
    Nova Scotia, Canada
    Excellent guys, thankyou. I'm thinking they should fit and I'm pretty confident that I can order them, this should not be as difficult as finding the quarter panels.
  5. RMay
    RMay Well-Known Member
    Rochester, NY
    I am guessing Fannie is the 68 Beaumont (Canadian version of a Chevelle)pictured in your Avitar. If so the rocker panels should be the same as a 68 to 72 ElCamino. Check some of the Chevelle catalogs for finding the best type and price.
    Wagons and ElCamino's are built on the same platform and usually have quarter panels that are about 3" longer behind the rear tires than a car panel. Again an ElCamino quarter that you can always trim down at the rear door may solve your quarter panel issues.
    I have been through all this with my 66 Malibu 2 door conversion project (http://www.stationwagonforums.com/forums/showthread.php?t=29015&highlight=rmay). After I used the longer ElCamino doors I needed the full 2dr panel length (complete with B-pillar) to allow for the elimination of my rear doors and it gave me the extra 3" rear length that is common on wagons. An ElCamino parts car was a key source for several parts I needed and so far the fit is looking very much factory.
  6. fannie
    Nova Scotia, Canada
    Yes, Fannie is my avitar picture. Thanks for the suggestion to use Elky rockers.
    As for the quareters they are under control, but I appreciate your help, thanks.
    http://www.stationwagonforums.com/forums/showthread.php?t=12479&page=17
    :wave:
  7. GN300
    GN300 Tipmaster G
    Aylesford Nova Scotia
    I got rockers (stamped ) for my van from uap they
    may stock older stuff ($44) each!
