rear hardware kit 12" drums
Discussion in 'General Automotive Tech' started by Forneby, Aug 16, 2012.
  1. Forneby
    Forneby New Member
    Sweden
    hi all
    its crazy, but i can not find a hardware kit for my 75 Grand Safari with 12" drums.
    all the kits i found are only for the 11" drums:cry:
    any ideas ?
  2. Krash Kadillak
    What size rear brakes did a mid 70's GM 1/2 ton truck have? I'll bet they are the same. If not, very close.
  3. Junk
    Junk Well-Known Member
    New England
    look for a kit for a rear wheel drive Cadillac from the early 1960's through the 1980's.. They are all the same.
  4. Forneby
    Forneby New Member
    Sweden
    thanks man:2_thumbs_up_-_anima
    i have ordered now the kit for Cadillac from Wagner F78540S
    its for 12" brakes:29:
  5. Junk
    New England
    The only thing that will possibly be different are the "nails" that hold the brake shoes to the backing plate at approximately 3 & 9 o'clock. The 12" brake shoes come in 2 1/2" and 3" versions for the Cadillacs. Replacements are sold in a box of 4 at Carquest or NAPA. Don't forget to clean and lube the threads on the self adjusters, and don't get the left mixed up with the right. Common error, since they both look the same. If you are not sure, pull the cap off, and it should be marked on the end.
  6. Forneby
    Forneby New Member
    Sweden
    thanks Junk:dancing:
