Prestone leak - Chevy Caprice 1990
Discussion in 'General Automotive Tech' started by franck74, Oct 27, 2008.
  1. franck74
    franck74 Montreal
    Montreal, Qc, Canada
    Hi Folks!
    Before i take my wagon to or mechanic, I'd like your opinion (my two other vehicles are air cooled and don't know much about water cooled problems and issues!!).
    After seeing a thread related to the TV cable that could be reset I went under the hood to proceed. I spotted some prestone on the manifold next to the carb.
    I dried it all out and drove the car a couple of miles = more prestone!! :-(
    So, is it major doctor? Note that the rad is brand new and all the hoses are 3 or 4 years old ( and about 20k miles)
    Thank you for your help and shared experience(s).
    franck
  2. tbirdsps
    You have a carb? If so possibly the base is water cooled or the thermostat housing is leaking?
  3. oldmopar
    oldmopar Well-Known Member
    NJ
    I would dry it up again then let the car run in your driveway and check to see where it is leaking from. It may take a few minutes before the thermostat opens and the water flows to the engine. As a blind guess I would make sure all the hose clamps are tight.
  4. franck74
    franck74 Montreal
    Thank you for those advice. Result: intake gasket leak quickly fixed with some sort of fluid. It's only temporary as I want this engine as reliable as possible. My mechanic is supposed to call me with an estimated price for the job. Looks like it's a 4 to 5 hours job! Woops.....
