Key Question
Discussion in 'General Station Wagon Discussions' started by detroit_inc, Jun 15, 2017.
  1. detroit_inc
    detroit_inc New Member
    Hello All! I recently picked up a 1968 Mercury Commuter wagon from a barn. This is an original 32k mile wagon with a 390 motor. My problem is that the car was purchased without keys. The doors are unlocked, but the rear is locked. Is it possible to unlock the rear door without the key? I do not see any lock latch.
    Thanks for any help.
  2. Poison_Ivy
    If you could remove the door panel without damaging it, you'd be on Easy Street.
  3. detroit_inc
    Can the door panel be removed with the door locked closed?
    Thank you!
  4. Poison_Ivy
    That should be possible, either through prying it off with an appropriate tool or through unscrewing the bolts which attach the door assembly to the body. The tools used for prying off door panels usually are double-sided. The opposite side being used for shoving off the clips holding the window cranks in place:
    detroit_inc likes this.
  5. KevinVarnes
    By rear door do you mean the rear side passenger doors or the tailgate?
  6. detroit_inc
    Sorry, I am referring to the tailgate.
  7. Krash Kadillak
    If it's a unit with the dual-facing rear seats, it's GOT to have a unkock knob on the tail gate somewhere.
  8. joe_padavano
    Northern VA
    If the doors are unlocked, pull one of the door lock cylinders. There may be a code stamped on the outside, allowing a new key to be made.
  9. detroit_inc
    Great idea - thanks!
  10. Silvertwinkiehobo
    That, or the tumblers can be pulled to discern what cuts a key gets. When I bought my '77 Datsun wagon, it didn't have an ignition lock cylinder, so, no key; the locksmith made a skeleton key, which I used at the old Pull-a-Part to get a lock cylinder assembly.
  11. detroit_inc
    Another great idea. Do you think a key can be made from the ignition cylinder? That would be the easiest to pull.
  12. 63Fowagon
    63Fowagon Well-Known Member
    Toronto, Ohio
    Your rear door should be same as door key . Ignition would be different .
  13. detroit_inc
    I have no idea how to pull the rear door cylinder with the door locked. Might have to pull a door lock and hope to get a key made from that. Thanks!
  14. Poison_Ivy
    Isn't there a code on the ignition switch you intended to pull?
  15. detroit_inc
    If I pull the ignition, I can replace it fairly inexpensively. The problem is the doors and the tailgate. Would there be a code on the door lock mechanism?
