Has anyone installed a Classic auto air?
Discussion in 'General Automotive Tech' started by earlyrides, Apr 22, 2010.
  1. earlyrides
    earlyrides Mopar or No car
    Santa Cruz Kalifornika
    I am having problems with my A/C. It blows dry and hot okay but not ice cubes.
    I think I may have a leak.
    Any suggestions?
    Early.
    Have you tested the pressure? The older ones had a 'view' window to see if the gas was ok. If you can't see movement, then odds are that its not fully charged or its leaking.
  3. tbirdsps
    The problem with old A/Cs is they don't take to 134a all that well but the fix is simple if you can find a condensor made for 134a that will fit and of course changing out the orifice tube.
    I've heard that Vintage Air makes a real good fit but I'm not familiar with Classic. I'm sure all these replacement systems are just about the same.
  4. Ford Nut
    Ford Nut Well-Known Member
    Occidental CA
    earlyrides
    I used them, Read my post in the resto forum. I was not happy with them.
    And the shipping will kill you.Vintage Air is in SoCa, I'v talk with a few guys that used them and gave them high marks.:thumbs2:
    Good luck. Rick
  5. Motion
    Motion New Member
    There is a dye that can be added to the system. Using a blacklight, the leak can be found.
    Ford Nut is right on. We install Vintage Air units on all the cars we do. Yesterday I started on an install on a 64 Galaxie. I've never had a problem out of one.
  6. Stormin' Norman
