Gas has dropped below $2.00 a US Gallon!
Discussion in 'Station Wagon Lounge' started by 1tireman, Dec 25, 2014.
  1. 1tireman
    1tireman Well-Known Member
    Slidell, Louisiana
    Gas is $1.98 a gallon here :dance: Not that it kept me from driving before and now I work closer than ever to my home but I had to do a double take when I seen the sign!
  2. ModelT1
    Only went by one filling station today. $2.39 at the BP station.
    If only my truck was fixed I'd make a few quick trips up north with a few loads of crap. Sure beats $4.00 a gallon.
  3. Eagle Freek
    Eagle Freek Well-Known Member
    Lowest I've seen it around here was $2.17. I heard it was $1.87 in parts of OK.
  4. BuLvr
    BuLvr USAF Veteran
    SE TN
    $2.13 gal. in Niota, TN is cheapest I've seen around here YET!
  5. jaunty75
    jaunty75 Middling Member
    Southeast Michigan
    Lowest here was $1.87 a couple of days ago. That station might be lower now. Most are in the $1.94 to $1.99 range.
  6. busterwivell
    busterwivell Bill, AZ Geezer
    Sahuarita, AZ
    Haven't been to town since Tuesday, but saw 215.9 then. May be below 2.00 by the time I go back to work on Monday.
  7. ModelT1
    Wouldn't it be great if regular got around $2.00 and stayed there ??????? :dance:
  8. capricestation
    capricestation New Member
    Germany
    Roundabout 5,90 $ here in germany.......:mad::mad:
    And thats cheap in the moment
  9. 101Volts
    101Volts Well-Known Member
    Pennsylvania
    I wonder if we're going to start seeing it at $1.39ish. It was around $2.40 today by the Brookville exit of I-80...
  10. jaunty75
    Southeast Michigan
    Do you mean $1.93?
  11. ModelT1
    When I worked part time in a filling station it was 32.9 for 100 octaine. Seems like every week there was a gas war and it would drop as low as 19.9.
    Wonder if it will go that low again? Considering the taxes are probably over $1.00 a gallon I doubt it.:banghead3:
    I'm happy when it's below $4.00.
  12. jaunty75
    Southeast Michigan
    No.
    Of the 50 states, the one with the lowest fuel tax rate is Alaska at 8 cents per gallon, and the highest is New York, at just over 50 cents per gallon.
    http://taxfoundation.org/article/state-gasoline-tax-rates-2009-2013
    I don't think we'll see gas at 32.9 cents per gallon again, but we might see $1.50. If it ever does go that low, in inflation-adjusted terms, that would be an almost historic low as it would be equal to, for example, about 28 cents per gallon in 1972.
  13. BillT
    BillT Well-Known Member
    Moneta, VA
    Today in Hardy, VA Regular was $1.93 (1.90 with Kroger card).
    With all the grocery shopping my wife has done lately, we built up an additional 40 Cent per Gallon discount.
    Sure is nice...
    Bill
  14. Steve-E-D
    Steve-E-D Well-Known Member
    Vancouver, WA, USA
    Regular is still $2.69 in my neighborhood. Premium $2.93.
  15. 1tireman
    Slidell, Louisiana
    Same station as my 1st post is at $1.89 today. The cheapest in town, most are holding steady at $1.99 and $2.00 so not all are below $2.00 yet, but like I said , it didn't stop me from driving before but at this rate I won't feel bad putting under $3 a gallon Premium in the '55 Chevy or 1tiredad's 9 mile to the gallon Malibu. May drive them to work once in a while for a change of pace. :)
