dual exhaust for 84 Chevy estate..
Discussion in 'General Automotive Tech' started by 84 bowtie estate, Jun 25, 2014.
  1. 84 bowtie estate
    84 bowtie estate Active Member
    lake saint louis mo.
    Can anyone tell me if a double hump cross member is made for my wagon?
  2. 84 bowtie estate
    Will one out of a 73-77 Monte Carlo fit?
  3. MikeT1961
    The cross member from the 90s Impala SS will fit, as they use the same basic frame. When my brother looked into a dual exhaust for his 86 Parisienne Safari with the 305, the shop was honest and told him NOT to do it. The reason given was that the 305 valve springs are weak, and need the back pressure of the single exhaust to work properly. He was warned that while the fuel economy would improve, the durability of the engine would be gone, and that he MAY get but another 30,000 miles out of it. By staying with the single exhaust, his engine was still healthy when the floor fell out of the car at 350,000 miles.
  4. 84 bowtie estate
    400 SBC built and ready for install. Using z28 valve springs and stainless valves.. Hedman 61608 headers. Going with dual cats and dual exhaust.
  5. 84 bowtie estate
    And the 94-96 impala cross member hangs from the floor pan. Not sure about the 91-93 caprice
  6. 84 bowtie estate
    Never mind that was a drive shaft catch or something on the floor board.
  7. Fred Kiehl
    Fred Kiehl Well-Known Member
    Largo, FL
    I used a partial section of an original crossmember and welded it to the top of the one currently in my car. Then I cut the bottom out to the inside of the top of the tube. Finally I welded scrap pieces over the open ends where I cut the bottom out.
  8. 84 bowtie estate
    So your wagon is a 91-96... Why not just buy a double hump from an impala or cadi.? Will my 73 Monte Carlo double hump fit? There has to be a way to do this with factory parts...
  9. 84 bowtie estate
    Everything interchanges on gm cars if you find the spot that never changed...
  10. The Stickman
    Lehigh Valley pa
    I just made one. Well to be truthful my wife made it.
