"clamshell" wagon window question
Discussion in 'General Automotive Tech' started by 72KingswoodEstate, Sep 24, 2008.
  1. 72KingswoodEstate
    northeast Tennessee
    The power rear window on my 1972 Caprice Estate wagon will open (which is up on these cars), but it will not close (down) under power. I can unhook the cable and manually wind the cable with a drill and it will close.
    I am assuming the motor itself is good since it will open, or could the "other way" be bad? I am thinking the switch is bad on the closing side? Any suggestions?
  2. tbirdsps
    That's what I would suspect. You could try to reverse the switch to see if that's the case. Then you'd know for sure.
    I've had to repair a few of those. Mostly Mopars, but I fixed a couple of GM switches by prying them open and cleaning the copper contacts with a fine finger nail file or some 220 grit oil-cloth sandpaper. In one case, I was able to use a small soldering gun and place a thin layer of solder and file it flat.
  4. Harry Clamshell
    The Netherlands
  5. aornest
    aornest New Member
    Poughkeepsie, NY
    Don't know if you're still having trouble... is it dead from both the dash and the keyswitch on the quarter? Jump 12 volts (yeah, I know, a long wire) to the terminals just to be sure.
    Adam
