Chafing sound behind instrument cluster
Discussion in 'General Automotive Tech' started by Fullsizelover, Sep 28, 2018.
  1. Fullsizelover
    Fullsizelover Active Member
    Holland
    Hi all, the past few days I hear a slight chafing sound, is that the speedo cable? It is still working but I wondered what else it could be? Thanks!
  2. OldFox
    It's totally possible. It will make a noise when it gets dry and it chafes at the bends. Unclip it from the speedo head and pull the cable out. Coat it with a very thin layer of grease and re-install.
    And hand spin the speedo head to make sure it's not the sound source.
  4. Fullsizelover
    Holland
    Thanks all, I didn't pull the cable out just squirted as many grease as I could and put some machine oil behind the speedo unit. An added bonus is that the needle also doesn't bounce any more between 10-20 mph.
    The bounce is an indication the cable was in need of lubrication.
  6. HotRodRacer
    Northeast Tennessee
    Yep. Binding/releasing, binding/releasing will make the noise and cause the needle to bounce as well. Good on you for fixing the issue.
