Anyone know if any body bushings are available for the 91-96 gm wagons? I done a search but couldn't find any threads on the subject. Are there any alternatives if none are available?
The only place I know about to start looking is here: http://www.rmsautoparts.com/search.php?pg=1&stext=body+bushing&sprice=&stype=&scat=19 I've seen aftermarket stuff on ebay.
Napa shows a Ballkamp part number 650-1184 refers to it as a body mount cushion. They show a retail of $8.39 each the car requires 4. Your Carrollton Ohio DC shows to have ten in stock. A local Napa should be able to get them in for you.
Another way to go is urethane from Energy. Links are to Summit: Small set for 91-96 Caprice 4 door (same as wagon? dunno): http://www.summitracing.com/parts/ENS-3-4145G/ Large set as above: http://www.summitracing.com/parts/ENS-3-4136G/ Don't know what the difference is between the sets. Energy <used to> have a link on their site to instruction sheets showing what goes where. Maybe Energy can tell you if these sets will work. I think you will need to supply bolts and inserts. Not affiliated with Energy, but I have installed Energy urethane body bushings on my 70 El Camino, like them, and am going to install them on my 70 Concours wagon. Really ties the frame and body together. Customer service for me has been good, also. Best regards, Tom
Some cars did not get the full complement of bushings. I think only the wagons and police cars got the full set, and the sedans did not.
You were right Dewey, that was the bushing I needed, thanks. Chevygod, that is the first time I've seen a whole set of bushings for the box wagons listed. Thanks again
No problem! I am glad to help anyone on the forum if I can. Working for Napa I am plugged into a lot of info and sometimes can even tell you which warehouse has something in stock.
