'95 RMW rear main seal leak
Discussion in 'General Station Wagon Discussions' started by brainiac, Jun 17, 2012.
  1. brainiac
    brainiac New Member
    Mechanic told me last week that my rear main seal leak is likely not able to be completely fixed so why mess with it. Any of you guys have actual experience with your roady leaking oil there and you couldn't fix it? Thanks.
  2. Dewey Satellite
    Dewey Satellite New Member
    Ogden, Utah
    That seems odd, even if the crank has an issue a repair sleeve would fix a seal surface issue...unfixable???
  3. 65 2dr
    65 2dr Fix 'em all -
    Chicago Area
    Get a 2nd and 3rd opinion - sounds like he really doesnt want to do it!
    Being a 1 - piece seal, I don't know if you've even gotta pull the pan.
  4. silverfox
    Make sure it is the rear main seal. Other mechanics have been fooled by the oil sending unit leaking. The unit is situated on the rear of the engine on the driver's side and when it leaks it runs down and gives the appearance that it is the RMS.
  5. Dewey Satellite
    Ogden, Utah
    Fox is right! I just had a customer that had the same diagnosis and found out it was his sending unit as well.
