I just pulled apart the steering column on my 89 country squire in order to replace the ignition switch. (I've done this many times on this and other wagons) When I pulled out the plug it shattered in 5 or 6 pieces.WTF do I do now.are replacement plugs available.the wires and connectors are all good.HELP!!!!!!!
Did you ever check to see if the ignition switch recall had been done on yours? That would be the easy way to have it changed free if not! Most pig tails are available, either after market or directly from Ford, so that does make it easier.
wireing diagram 89 ford country squire ignition switch Can any body direct me to a diagram for the ignition switch plug????:banghead3:
